Smashed Gravely repair.
发表于 2021-9-1 00:18:24 | 显示全部楼层 |阅读模式
A friend of mine purchased an old Gravely mower that probably predates me by a few years, and promptly smashed the deck. He claims that a gaurd came loose and got into the blade... I'm not buying it.  The side that was smashed got the BFH treatment against a piece of flat plate and was deemed close enough. The gap did not want to close up, so I buttered the sides of the paper thin old steel with 1/16" 6013 DCEN at about 50 amps.  Not quite to pipefitter's standards, but good enough for an old Gravely. When it was close enough to weld together I ran 3/32" 7018 DCEP  around 100 amps. While I was arcin' I fixed a few other cracks. The ski did not get repaired. I asked if he wanted to straighten it, and he said no. Since my fee for the job was only 5# of 3/32" 7018, I did not go further. A few more pics in the next post... Attached Images
Reply:Note the rust hole in the side of this first pic. That part is not much thicker where I worked on it.That's all folks! Attached Images
Reply:I have a gravly.  I can see how it could happen.  Looks pretty good.DavidLast edited by David R; 06-12-2008 at 09:20 PM.Real world weldin.  When I grow up I want to be a tig weldor.
Reply:You rebuilt it.   Good work too.Old horsebarn for a shopBig scrap pile out backMiller Syncro200Lifelong collection of toolsBunch of other crapUnderstanding wifeUnderstanding neighbors
GMT+8, 2025-12-22 16:29 , Processed in 0.109954 second(s), 18 queries .
