i made some lower control arms for my stang,because i can and im to cheep to buy them from the store.fords and mineLast edited by chopper5; 06-14-2008 at 06:34 PM.ChuckASME Pressure Vessel welder
Reply:wheres the pic of the stang?? 05 and up i believe?AWS CWI/CWEASNT NDT Level 2 PT/MTAWS Certified Welder(aerospace)
Reply:If yours are the darker colored ones , then you do not need the ford parts at all. Nice work.
Reply:yes it is a 2006 GT,the ones made of tubing are mine fords uses stampingsChuckASME Pressure Vessel welder
Reply:did you unhook the emergency brake cable? i have seen people just cut em with a torch..AWS CWI/CWEASNT NDT Level 2 PT/MTAWS Certified Welder(aerospace)
Reply:the E cable just un clips dont need any tools ,so there is no need to cut any thingChuckASME Pressure Vessel welder
Reply:what is the weight difference between yours and the stock ford piece?
Reply:not relay shore but having one in each in hand fords feels heaverand the bushing in the factory part are soft rubber mine are poly ,lot stiffer the tubing is1.125 OD. Dom .120 wall because that is what i hadChuckASME Pressure Vessel welder
Reply:Point of doing this? Just curious if you weren't going for a weight decrease...
Reply:better handlingChuckASME Pressure Vessel welder
Reply:Looking good, Chopper!!http://all-a-cart.comWelding Cart Kits and accessories
Reply:thank you ZTChuckASME Pressure Vessel welder
Reply:Originally Posted by m R g S rPoint of doing this? Just curious if you weren't going for a weight decrease...
Reply:Originally Posted by m R g S rPoint of doing this? Just curious if you weren't going for a weight decrease... |
