finally wired garage for tig welder
发表于 2021-9-1 00:18:15 | 显示全部楼层 |阅读模式
I finally got around to wiring the garage for my sync200 I bought 4 months back.  I thought I would use it on a gate project already in progress that I'm building to keep my 2 year old son from going on the deck to the pool area. Most welds were done by mig but thought I would use the tig on the gate stop.I made 2 passes on some scrap then made this pass. Now it's not the best pass since I haven't tig welded in 3years so I've got to get back in the groove of things but it will do. Attached ImagesLast edited by hytekredneck; 06-17-2008 at 02:01 AM. It's not what you can buy, it's what you can build that matters
Reply:I wanted something light weight but made from metal so I used EMT 3/4 inch for the main frame and 1/2inch for the bars since the wall thickness for EMT is about 18gauge. I've got less than $15.00 into it and a piece of mind once it's finished and installed. Priceless Attached ImagesLast edited by hytekredneck; 06-17-2008 at 01:57 AM.Reason: speelling It's not what you can buy, it's what you can build that matters
Reply:Spacing looks a little wide- little dood may get his noggin stuck tryin' to get through itEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:I agreeMake sure to go with your local building code for spacing...
Reply:Originally Posted by Broccoli1Spacing looks a little wide- little dood may get his noggin stuck tryin' to get through it
Reply:Cool- Little buggers can get in to and everywhere once they get their legsEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
GMT+8, 2025-12-22 17:47 , Processed in 0.198105 second(s), 18 queries .
