Rod help
发表于 2021-9-1 00:18:12 | 显示全部楼层 |阅读模式
I got a 50lb box of Lincoln Fleetweld 22 1/8" rods at an equipment auction for next to nothing (whole shelf of stuff for $10).  I know it's primary use is spotwelding decking.  Since I don't do that... is there any other general applications for this rod or will I just end up burning holes thru everything I try to weld with it?
Reply:id say you can use it on heavier stuff you might tink around with.  Watch the amps and this stuff has good penetration, but keep limited to flat position.  I wouldt use it on anything critical.   but im sure you can find things to tinker with   good luckIF it Catches...Let it Burn
GMT+8, 2025-12-22 17:40 , Processed in 0.068297 second(s), 18 queries .
