My First Square to Round
发表于 2021-9-1 00:18:09 | 显示全部楼层 |阅读模式
17 foot 8 inches tallround is 54 inches in diametersquare is 6 foot by 4 footoffset is 2.5 foot Attached Images
Reply:All I got to say is S----- thats one big unit.
Reply:Holy Crap!!Now thats big!...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:yeah it took 7 10 hours days from raw material to this.2 men. the shop almost wasent big enuff. and of course the prents were not right had to modify. thats what my partner is doing with the toarch. cost us some time .
Reply:Any weld pics?You know..The usual questions..Amps..Method..Machine...We want answers Dammitt!!!!!...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Does that by change get hooked up to some industrial air filtration equipment?
Reply:Todd,How about you PM me the name of the shop you work for and its location. If you guys can do that stuff , I might have some work for you( little bigger though )insert thoughtful quote from someone else2000 Thermal Arc 300GTSW 3.5 hours1946 Monarch 20 x 54 Lathe1998 Supermax 10x54 Mill2004 Haco Atlantic 1/2" Capacity Lasernot mine but i get to play with it
Reply:nice workM Fed
Reply:glad you started off with a small one
Reply:Looks like you have a little offset to it as well. Nice job. Never did one that big, I can see why you need two guys on that puppy. Did you figure out the layout of the sides, I've never done one from scratch, I always had templates. There are some formulas for figuring those things just never used one. Whats is its application?Good judgement comes from experience.Experience comes from bad judgement.
Reply:What IS IT?     I once worked in a coal-fired power plant and they had similar setups for feeding the coal from the  conveyors into the grinding mill hoppers....   Am I close???Lincoln AC225 & MigPak 140, Lincoln Magnum SpoolGun, Miller Spectrum 375-X Plasma, Syncrowave 200 TIG, Millermatic 252 MIG, Miller Digital Elite, General 7x12" horiz/vert bandsaw, 3' box/pan brake, 20 ton press, milling machine, 12x28 lathe, etc.
Reply:Nice job.....Mike
Reply:Nice work,thanks for showing the pics.I like seeing stuff like that.pro-level dumpster diver                                     Hobart 125EZ
GMT+8, 2025-12-22 17:46 , Processed in 0.165920 second(s), 18 queries .
