Miller Aluma Pro push pull gun
发表于 2021-9-1 00:18:06 | 显示全部楼层 |阅读模式
I have a miller aluma pro push pull gun, and not very happy  with it,My question is do others like or dislike theres and why.
Reply:What do you dislike about it?Who is John Galt?
Reply:I had one for almost two years. We've had a few problems, but for the most part It works well.i was a prince spool gun guy for 15 yrs before I got this. There are places that the aluma pro can't get into,. For the most part it works well. We have put about 800 lbs of wire run threw it. Its connected to a invision MPA. You have to blow the liner out in between each 15 lb spool. Being a mk products personm I wanted to put the my python gun on the feeder when we bought it. The miller rep talked us out of it, said the miller gun had a higher amperage rateing.
Reply:Originally Posted by bassboy1What do you dislike about it?
Reply:I have never tried one of the push pull units because the spool gun works so damn well. The only time I have an issue with the spool gun is when I hit the end of the spool.Miller 302GMIller 12RC SuitecaseMIller 30A spoolgunHF-251D-1WP17 Tig torchSmith HD torchHypertherm 45Jet drill pressHF 7X12 wet cut horizontal band sawPlasmacam CNC table
GMT+8, 2025-12-22 18:21 , Processed in 0.073556 second(s), 18 queries .
