just wondering
发表于 2021-9-1 00:18:05 | 显示全部楼层 |阅读模式
just wondering , I have a old tig/stick welder that I don't use, can I hook up a wire feeder to it to run mig wire   thanks for any information you have
Reply:It depends on the welder, I think...[Account Abandoned 8/8/16 Please Do Not Attempt Contact Or Expect A Reply]. See you on YouTube! -ChuckE2009
Reply:the welder is a lincoln 300T
Reply:You can, but you need a feeder that is compatible with a CC (constant current) power source, most mig power sources are CV (Constant voltage).  I have been tolds the arcs are not as smooth or easy as a dedicated mig power source but have no personal experience with them.
GMT+8, 2025-12-22 19:30 , Processed in 0.455510 second(s), 18 queries .
