Jackson EQC Professional Variable
发表于 2021-9-1 00:18:05 | 显示全部楼层 |阅读模式
Have had this for so long I forgot when I bought it. Keep in the F350 4 Door 4X4. Have not damaged it yet. How do the professional store their helmets in the truck. Is here a better way than throwing it in the back???
Reply:they make helmet bags
Reply:On top of the gloves, kneepads, and sleeves, window up.
Reply:Originally Posted by Cat220 Is here a better way than throwing it in the back???
Reply:Thanks. Cleaned the Jackson EQC up last night. Must have had sweat, spilled coffee, and other dirt I coudl not identify. New lens and batteries. I did not know how the pros stored it. Now I know. It goes back to the back of my 1997 F350 4X4 Four door with over 400,000 miles on it. Need to give truck a spring cleaning as well. To Cold and To much Snow this year.
Reply:just open the doors and blow everything out with the pressure washer. leave the doors open so it will dry while you sort through the stuff you blew out and try to remember if it's worth keeping.225NT bobcatAEAD200LEScott 125mm175, mm252 w 30A, PT225mm211, TA 181iHyper Therm 380, cut master 529100X & XX, Digital Elite6 Victor setssmith little torch, meco midget kalamazoo band sawsteel max saw evoulution circular saw
Reply:i think i would make a hook to hang it up on the drivers side upper cornerWELD TO LIVE LIVE TO RIDEA bad welder blames his equipment, a good weldor can lay a perfect bead on any thing
GMT+8, 2025-12-22 17:59 , Processed in 0.112192 second(s), 18 queries .
