welding cylinder shaft
发表于 2021-9-1 00:18:02 | 显示全部楼层 |阅读模式
im having trouble with porosity welding eyelets on cylinder shafts the eyelets are usually oily and dirty. what is a good filler rod. im using er70s6
Reply:clean them the best you can,and try 6011,6013o9r 6010.There made to cut through the oil and dirt and also give decent pen.
Reply:Originally Posted by toolwelderim having trouble with porosity welding eyelets on cylinder shafts the eyelets are usually oily and dirty. what is a good filler rod. im using er70s6
Reply:Or perhaps you should consider getting a wire brush attachment for your grinder. They clean oil off great.
Reply:Anyone ever seen a cylinder blow up while being welded on?Thanks!
Reply:I've seen a lot but never seen that. Have you? I've welded on a bunch of cyl. and never thought of that as being an issue. Is it?
Reply:Originally Posted by fyoungAnyone ever seen a cylinder blow up while being welded on?Thanks!
GMT+8, 2025-12-22 17:59 , Processed in 0.096749 second(s), 18 queries .
