_Mig & Arc Welder Cart
发表于 2021-9-1 00:17:56 | 显示全部楼层 |阅读模式
This is my first post here and my first completed project with a new MIG welder.  I've placed more photos of the cart (and for newbies, step-by-step instructions) on my website.Check them out at:http://www3.telus.net/davejewers/main/Migcart/index.htmAny comments would be very much appreciated.Cheers,DaveLincoln AC225 & MigPak 140, Lincoln Magnum SpoolGun, Miller Spectrum 375-X Plasma, Syncrowave 200 TIG, Millermatic 252 MIG, Miller Digital Elite, General 7x12" horiz/vert bandsaw, 3' box/pan brake, 20 ton press, milling machine, 12x28 lathe, etc.
Reply:Nice looking set-up Dave..Clean and to the point!.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:I was thinking about a Lincoln buzzbox, but might go with the hobart.  Looks like a setup that will work well.
Reply:Now that you got that mig, how much is the ol buzzbox going to be used?Nice cart.Need close ups of the welds.  DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:David R:  My plan was always to keep the buzzbox- It has a tremendous amount of power to do anything I could ever need.  I got the Mig-Pak 140 to do the light stuff that the buzzbox (even on it's lowest setting) would vaporize.  And for those wondering- I absolutely love both of them.Lincoln AC225 & MigPak 140, Lincoln Magnum SpoolGun, Miller Spectrum 375-X Plasma, Syncrowave 200 TIG, Millermatic 252 MIG, Miller Digital Elite, General 7x12" horiz/vert bandsaw, 3' box/pan brake, 20 ton press, milling machine, 12x28 lathe, etc.
Reply:Oh, and the weld closeups... I didn't take too many weld-pics while building it (and as you can see the ones I did take are not on my website with the others)... but I do have a couple. Keep in mind a couple of things:   I learned to weld from reading books (never had a course) and this is my first time EVER using a wire-feed welder.  Secondly, it was welded using flux-cored wire (no gas) so they're a bit messier.  Looking forward to your constructive criticism.Anyway, the photos.... Attached ImagesLincoln AC225 & MigPak 140, Lincoln Magnum SpoolGun, Miller Spectrum 375-X Plasma, Syncrowave 200 TIG, Millermatic 252 MIG, Miller Digital Elite, General 7x12" horiz/vert bandsaw, 3' box/pan brake, 20 ton press, milling machine, 12x28 lathe, etc.
Reply:That's not going anywhere soon..Nice job.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:NICE welds!DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:I would say you've got it.Tim Beeker.
Reply:Thanks for the comments, guys.  Any more comments on the quality of the welds?Lincoln AC225 & MigPak 140, Lincoln Magnum SpoolGun, Miller Spectrum 375-X Plasma, Syncrowave 200 TIG, Millermatic 252 MIG, Miller Digital Elite, General 7x12" horiz/vert bandsaw, 3' box/pan brake, 20 ton press, milling machine, 12x28 lathe, etc.
Reply:the welds look pretty good for being single-bead, straight line... whatever you want to call them. try weaving or zig-zagging a little... it will give a little more wire deposit, but it also puts in more heat, meaning more penetration. i heard from an old friend of mine to use a small putty knife to knock off slag and spatter... i RARELY use a hammer any more. the knife works much better at taking up them little berries.Later,Andy
Reply:good job
GMT+8, 2025-12-22 19:30 , Processed in 0.265395 second(s), 18 queries .
