Need some help - farm bell
发表于 2021-9-1 00:17:55 | 显示全部楼层 |阅读模式
I recently inherited our family farm bell.. Been handed down through my great grandfather through every generation..  I sandblasted it, and put a coat of rust-oleum primer and two coats of black on it, sunk a 6x6 pressure treated post and re-mounted.  The problem is the bell clapper (the thing that hangs down and hits the sides of the bell)... It looks like part of the hook to hang it in the bell has broken off (first picture below, on the left side is where it broke off).. I think the bell is cast iron, but not sure.. I am a hobbyist mig and tig'er, but not sure the best way to attack this one.. Can I tig cast iron?  The bell has a date stamped on it of 1886..   Wife wants to be able to ring it to bring the kids to dinner, but been struggling how to fix..  Any ideas are appreciated... Attached Images
Reply:Rather than trying to weld it I would try and cut it off at the straight part and find a way to clamp a new piece of steel to it to make the hook.Have we all gone mad?
Reply:i use ni 44 filler rod when tig weldind cast iron
Reply:I'm pretty sure it's the shaft on the "clapper" that you need to repair. Are you sure it is cast iron? I'd have expected something like that not to be made of cast iron and more likely to be steel, or worked iron from a blacksmith and more likely more easily welded. It's really only been a hook to hang on the ring in the top of the bell. Does the bell come apart at all, in order to get the hook on the ring. i.e. is there a through bolt that holds the bell onto the piece that it hangs and swings form, that in turn goes through to the inside of the bell and incorporates the ring for the clapper to hang on?"One of the things we have to be thankful for is that we don't get as much government as we pay for." (Charles Kettering)Mitch 180 (NZ)Lincoln SAM-400-220 + ?-400 Fordson Major + 2 x Tractapac Humber 80 + Procut 40 PlasmaMiller Spectrum 375
Reply:Give it a spark test.  Short red sparks that don't travel more than a foot or two away from the part?  Then its cast iron.  Long yellow sparks that go 5 feet or have a tail are steel.Let us know what you get.DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:How big is the diameter of the broken shaft?There just may be a way to fix this without welding anything.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:I'd vote for cut it off flush at the "ball", drill and tap to size. Thread some straight rod and bend it however you'd like. No welding, done without a fuss.
Reply:Looks like an old bell from a locomotive. I agree that I think its the clapper that needs to be repaired. If so it's no big deal. You could just fasion a new clapper from a chunk of steel and plain rod ignoring the old clapper altogether. Some carful heat and you may beable to bend the old rod to a new hook. I'd heat as much of the rod as posible and then slowly try and pend the end. let it cool slowly afterwards. As also suggested you could cut off the old rod, drill and tap and add a new rod and hook to the old clapper.
Reply:Originally Posted by DSWLooks like an old bell from a locomotive. I agree that I think its the clapper that needs to be repaired. If so it's no big deal. You could just fasion a new clapper from a chunk of steel and plain rod ignoring the old clapper altogether. Some carful heat and you may beable to bend the old rod to a new hook. I'd heat as much of the rod as posible and then slowly try and pend the end. let it cool slowly afterwards. As also suggested you could cut off the old rod, drill and tap and add a new rod and hook to the old clapper.
Reply:I can not tell if the underside of the bell has a loop to attach the clapper shank; if it does, that's good. If not, I would attach a small piece with an appropriate hole and a large base (Maybe "T" cross section) using Epoxy. If only the clapper shank is 'broken', I would test it by bending the tip or doing the spark test to be sure it was steel. If it is, a new piece of rod is easily added to get the right length and to bend a hook in.If it also seems to be cast iron, just report back for more ideas. Usually, the clapper was cast in a mold holding the steel rod  to make it all one piece when done.
Reply:I've repaired several.  Cut the rod off at the ball, and braze a piece of 3/8" cold roll on to it.  then you can heat the cold roll, and bend a hook on the end.I'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
Reply:I'd be tempted to put the old clapper away and manufacture another.  that way you won't care too much if you screw up.  Frame the old clapper and hang it over the mantel.
Reply:It looks like you can maybe bend it to make a hook from that one just to keep it original. If not, I agree bye another one and hang on to that one.I carry guns because cops are too heavy. .. ..-.   -.-- --- ..-   - .... .. -. -.-   .... .- .-. -..   . -. --- ..- --. ....   -.-- --- ..-   -.-. .- -.   ..-. .. --. ..- .-. .   .- -. -.-- - .... .. -. --.   --- ..- -
Reply:Thanks for the all the feedback and ideas.. I tried tig'ing a hook on the end and it glowed red (not much spark) and seemed really brittle... So, I cut the rod off flush with the ball on the end, drilled and tapped it and put in a piece of all-thread the same length as the old hanger.  At the top I cut off a hook bolt and tig'd it to the all-thread.. Shot on some black rust-oleum and I think it is back in biz.  Hung it in the bell and both kids rang the daylights out of it, so  I think it passed the initial stress test.. Attached Images
Reply:Nice work. A family heirloom to be treasured for sure and also to be handed down to future generations. Enjoy it with your family. Happy fourth of July.Sign on East Texas payphone: Calls to God 40 cents......it's a local call...
Reply:Looks great
GMT+8, 2025-12-22 18:06 , Processed in 0.095662 second(s), 18 queries .
