.060 Aluminum Thingies..
发表于 2021-9-1 00:17:55 | 显示全部楼层 |阅读模式
Customer came in and asked if we weld Aluminum.."Sure Do" I said.."Well I have some parts I need welded and my usual shop is on vacation..Can I get 12 done this morning?""Why not" I said.."I've even included a sample piece so there will be no questions OK?""Sure thing" I said..Well I think we just got a new customer..Here is his sample done wherever he was going..Here is My piece..Comparison..I think he will be back...060 6061-T6511/16" Red End...045 4043 filler..60 amps tops..Straight Argon..I never use the mix on thin stuff..It gets TOO Hot TOO Fast..I get all the fun jobs.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Looks like you need more practice Zap. Your's doesn't look anything like the sample piece.
Reply:Originally Posted by 737mechanicLooks like you need more practice Zap. Your's doesn't look anything like the sample piece.
Reply:The previous shop should be embarrassed. I hope your new customer shows the old shop why he left. It looks like you let the AC do the cleaning. Anything more? TIA, Craig 9-11-2001......We Will Never ForgetRetired desk jockey. Hobby weldor with a little training. Craftsman O/A---Flat, Vert, Ovhd, Horz. Miller Syncrowave 250
Reply:Originally Posted by Craig in DenverThe previous shop should be embarrassed. I hope your new customer shows the old shop why he left. It looks like you let the AC do the cleaning. Anything more? TIA, Craig
Reply:looks like youll have a new customer
Reply:Do you point and truncate your red tung? X-former or inverter?Do you bow the pieces back, so they will pull straight? Or do you just bend them straight after cooling? Or did the customer just take them kinked? Ok, I'll quit. 9-11-2001......We Will Never ForgetRetired desk jockey. Hobby weldor with a little training. Craftsman O/A---Flat, Vert, Ovhd, Horz. Miller Syncrowave 250
Reply:Originally Posted by Craig in DenverDo you point and truncate your red tung? X-former or inverter?Do you bow the pieces back, so they will pull straight? Or do you just bend them straight after cooling? Or did the customer just take them kinked? Ok, I'll quit.
Reply:Pretty nice, as usual.For the end of the weld, you 'double-dipped' the filler to fill the ending crater?Just clamped/jigged it square and then weld in one shot, or did you tack both sides a couple places and then weld?Yeah, those 'sample' welds are u-g-l-y.  The scary/bad part is, I think we've all seen worse!
Reply:Originally Posted by zapsterSharpened to a very sharp point..Its a '74 Hobart Biggie thing..600 lbs????Oddly enough they stayed flat!!...zap!
Reply:Originally Posted by MoonRisePretty nice, as usual.For the end of the weld, you 'double-dipped' the filler to fill the ending crater?Just clamped/jigged it square and then weld in one shot, or did you tack both sides a couple places and then weld?Yeah, those 'sample' welds are u-g-l-y.  The scary/bad part is, I think we've all seen worse!
Reply:Nice beads,Dude that sample is rough, I would love to hear from the guy that does that."Yeah, this thin aluminum just doesn't weld like it should, I had to shut off the gas and drag the tungsten"Yup
Reply:Woohooo! Some nice craters on the sample piece!!  John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Originally Posted by zapsterI still have a dozen to do next week..Need a show?...zap!
Reply:Don't get discouraged.  If you practice enough, you can probably make one look as bad as the one he brought to you.
Reply:Zap,nice work again, where are you located? anywhere near MN?-Dan
Reply:The shop is in North Attleboro, Mass..Only a few short hours away by Jet Airliner.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:i weld 100x better then that and im in high school!!M Fed
Reply:Originally Posted by eyeshurti weld 100x better then that and im in high school!!
Reply:Any advance on 100 times? Oh, was that better than Zap, or the sample welder?  "One of the things we have to be thankful for is that we don't get as much government as we pay for." (Charles Kettering)Mitch 180 (NZ)Lincoln SAM-400-220 + ?-400 Fordson Major + 2 x Tractapac Humber 80 + Procut 40 PlasmaMiller Spectrum 375
Reply:those teenagers think they are knowitalls and invincible. You will learn young padawan.
Reply:Originally Posted by mnm4l1f3those teenagers think they are knowitalls and invincible. You will learn young padawan.
GMT+8, 2025-12-22 17:59 , Processed in 0.071038 second(s), 18 queries .
