Welding Wire & Electrodes
发表于 2021-9-1 00:17:53 | 显示全部楼层 |阅读模式
I need to know if there is a difference in using 7011 Flux cored wire or a 7018 electrode. My foreman says it's not good to use the wire on AR400 plate, but it's alright to use the electrode. I would like to know if anyone agrees to this?
Reply:what is the situation here? what kind of weld bead, material thickness, etc? that may play a factor in it.Later,Andy
Reply:No they are not the same. To equal 7018, you need a -8 wire.DavidReal world weldin.  When I grow up I want to be a tig weldor.
GMT+8, 2025-12-22 18:06 , Processed in 0.116950 second(s), 18 queries .
