Weldability of 7475 AL
发表于 2021-9-1 00:17:49 | 显示全部楼层 |阅读模式
Does anyone have experience in welding 7475 AL?  If so what type process and filler work best from your past experience. Thanks Gina
Reply:FYI (incase anyone ever runs across this question themselves)I found out what I thought was true but wanted to verify.....7475 is similar in chemistry to 7075, 7075 has a reputation as being non-weldable. The additions of Cu and Mg to these Al – Zn base alloys results in an inherent problem, after arc welding, associated with stress corrosion cracking and for this reason they are not usually welded in any structural applications.
Reply:Resistance welding methods work well on 7xxx series aluminums.
GMT+8, 2025-12-22 18:02 , Processed in 0.091128 second(s), 18 queries .
