looking for something to make this type of picket end Attached Images
Reply:http://www.vogeltool.com/form_pickets.html
Reply:I believe scotchman also makes a die like that for their ironworkers, which you could use in a hydraulic press- they call it a "picket tool".http://www.scotchman.com/tooling_options.php
Reply:thought i could get something for around $500 thank for the good web sitessorry for putting this post here wanted it under machines and tools
Reply:You could probably have a pair of dies made for you.
Reply:I imagine you want to make a good number; if not, you could probably machine a crude 2-piece die and hot forge the ends using a charcoal fire. |
