My new toy!
发表于 2021-9-1 00:17:46 | 显示全部楼层 |阅读模式
Had to borrow the wifes camera to post these.Just picked this up yesterday. 2000 Lincoln Commander 500D, Deutz diesel, 1744 hrs. Needs a new battery, I used a spare side post for temp. Didn't get much time to play with it yesterday. And today we have a family thing, so sunday you know where I will be!Runs great and it welds. I just tested it with a couple of 5/32 7018 rods really quick. Cranked it up and was cuttin 3/8 with the 7018. I bought it from an Airgas for $2250.00. It sat for a couple of years, it used to be a rental unit. I want to paint it in spring. Original or red??? I prefer red, but I need some input on that. I will let you know more tomorrow.Last edited by Stick-man; 03-12-2011 at 11:47 AM."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:"Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:nice find Stickman. that ought to get some rod cookin. put that puppy on your truck and you even have a nice little trailer to haul you quad around.225NT bobcatAEAD200LEScott 125mm175, mm252 w 30A, PT225mm211, TA 181iHyper Therm 380, cut master 529100X & XX, Digital Elite6 Victor setssmith little torch, meco midget kalamazoo band sawsteel max saw evoulution circular saw
Reply:Looks like a real workhorse!Congrats !rc
Reply:Originally Posted by jbmprodsnice find Stickman. that ought to get some rod cookin. put that puppy on your truck and you even have a nice little trailer to haul you quad around.
Reply:Have you tried polishing that paint job first?I would leave it the original color. Red would work too , but you will have to get new decals.OR....Paint it Miller blue, and make people's head spin.LOL...Too bad the owners did not take care of it. I mean you know how much does a tarp cost.Last edited by Donald Branscom; 03-12-2011 at 02:07 PM.AWS certified welding inspectorAWS certified welder
Reply:nice
Reply:Not bad, not bad at all!  Congratulations on a great deal!
Reply:Originally Posted by Stick-manJust picked this up yesterday. 2000 Lincoln Commander 500D, Deutz diesel, 1744 hrs.
Reply:Originally Posted by Broccoli1a 2000 year rental unit with only 1744 hours?1744/24hrs = 72 rental days if they only used it 1 hr a day- and I assume they get used more than one hour so they got way less than 72 billable days out of that machine= lossHow much does/did a Commander cost to rent?
Reply:Originally Posted by tbone550Uh Broccoli, if it only got used one hour per day it had 1,744 billable days.If it was used 24 hours per day, it would've been rented 72 days.
Reply:I'm going have a brew nowEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Well it was a rental unit for Airgas or AGA. Then they formed Red-D-Arc as their rental and Airgas stopped renting. He told me it sat for 3 or 4 years. The oil looked fresh, but the hours on the filter said something like 15xx hrs. I think. This unit was not up for sale. I went there, because I was in the area, with my new Hobart gas drive to see if they had a polarity switch. I was told that it might be the same as some newer models. So I got to talking with the mechanic and told him I was looking for a CC/CV diesel drive. He showed me this that has just been sitting there. After himmin and haw'n, I ended up with it. Just looking at it I believe the hour meter is correct. I have the same engine in my Ingersoll tow behind compressor which is older and the hour meter says less hours, but the welder runs alot better and has no oil leaks."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:Originally Posted by 7A749Get some 3/8" carbons & hook 'em up to yer Airarc (I know, not a K 4000, just use common sense! ). Crank it up about all the way & go for it. You'll have a hardon that won't go away for a few hours the first time you touch it off. www.billswelderrepair.com Will have the correct paint code. Personally, I would just pop a panel off when it comes time & take it in to a local automotive paint shop. They should be be able to easily match it with a spot on the inner part that isn't weathered.Good luck with it.
Reply:Originally Posted by 7A749You got a nice machine for what you spent. Sounds straight to me. That Duetz will run a long time if you take care of it. Hope the unit checks out OK in CC & CV. I bet it does tho. Don't think anyone was trying to screw you around by the looks of it.Get some carbons & post your results. Your wife will look at you in an entirely different way after you cut some steel with the BIG carbons! Have fun with it!!
Reply:Nice find stickman! Thats a good machine. Should be here after were all gone! I would paint it blackish grey again, looks badass!You have to learn the rules of the game. And then you have to play better than anyone else. Albert Einstein
Reply:PS: Put a lock on that thing!You have to learn the rules of the game. And then you have to play better than anyone else. Albert Einstein
Reply:congrats.. for  suggested paint scheme see foto Attached Images
Reply:Originally Posted by 7A749I'm already jonesing for a CAC fix.......... I think the 4000 is 1200 amps? Can't remember. I have one, but nothing to run it from at anywhere near it's full potential. I'm jealous.........  You'll do fine with what you have. It's a great CAC torch. They make the best IMHO.You'll get lots of life out of that machine & you didn't pay too much either.I have welder envy........
Reply:Originally Posted by jreynoldsweldingPS: Put a lock on that thing!
Reply:Originally Posted by weldbeadcongrats.. for  suggested paint scheme see foto
Reply:I tried out the plasma from the Commander today and . Then I tried my wire feeder with some FC and . Stick-man is VERY happy.Now I just have to figure out why it will not go to low idle. It starts on high, tries to go to low once, then stays on high??? I will post this question in the Lincoln page too."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:Originally Posted by Stick-manI tried out the plasma from the Commander today and . Then I tried my wire feeder with some FC and  Stick-man is VERY happy.Now I just have to figure out why it will not go to low idle. It starts on high, tries to go to low once, then stays on high??? I will post this question in the Lincoln page too.
Reply:Stick.....AWESOME BUY!!!So glad for ya' Bro !!!JDOriginally Posted by Broccoli1it's because it has 1,744 billable days on it
GMT+8, 2025-12-22 18:02 , Processed in 0.099855 second(s), 18 queries .
