查看: 13|回复: 0
Got my Weldanpower 225 AC/DC!
发表于 2021-9-1 00:17:44 | 显示全部楼层 |阅读模式
Some may remember my questions or ramblings in other posts...Picked up my "Big Red" 9112 Weldanpower AC/DC. Briggs and Stratton power plant, NO CV Serial ( and Duane, through other posts ) tells me its a late 1987 model.Carb will need attention. But she runs- rough, suspecting float is stuck. My Stars, is this thing heavy, bout blew my balls out shoving it up my ramps into my truck..Reading similar posts, Im taking their advice, and running new fuel lines, then Im cleaning the carb. Slip rings look good, havent Ohm brushes yet. Current taps, and fine adj taps look clean, nothing burnt, looks good to my un-trained eye!!Does anyone know where I can dig up info on the Briggs? The cover was painted, and I think the model # is covered now...Or am I looking in the wrong place?MaxLincoln Power MIG 210 MP ( boat anchor )Lincoln Weld-Pac 100 HDHobart IronMan 230Cutmaster 42Jackson NexGenSumner Ultra ClampsDWM120
Reply:no pics?! subscribed regardless. let us know how it goes. i just recently got mine too. weldanpower 250 g9 pro. cant wait to burn some rod!Ranger 305gMillermatic 140 AutosetDewalt Chopsaw2 grindersMy Fists
Reply:Originally Posted by MadMax31Does anyone know where I can dig up info on the Briggs? The cover was painted, and I think the model # is covered now...Or am I looking in the wrong place?
Reply:Thanks Duane!! Had to remove paint and found the Model, Type and Code number...Found a website with all the diagrams, part numbers and Prices...Ill take pics shortly, up first is carb inspection/cleaning. Gonna sniff the oil. Gas tank inspection, new fuel lines and filter. Bought a new battery today as well.Ill try to snap pics as I go, but once Im in the zone, I just motor along. Ill try though.Lincoln Power MIG 210 MP ( boat anchor )Lincoln Weld-Pac 100 HDHobart IronMan 230Cutmaster 42Jackson NexGenSumner Ultra ClampsDWM120
Reply:Carb apart, gaskets are a mess... New ones ordered, as well as air filter, Idle jet, and float needle, looked worn. Bowl has the awful Ethanol residue...Cleaned it all up.Gas Tank looks decent inside. Ordered new petcock, old one is seized, not too mention plugged.Pulling head next to give top end visual inspection, just incase....Checking oil tomorrow, sniffing for gas...Lincoln Power MIG 210 MP ( boat anchor )Lincoln Weld-Pac 100 HDHobart IronMan 230Cutmaster 42Jackson NexGenSumner Ultra ClampsDWM120
Reply:Good job on pulling the head. decarbon it and the valves and tourqe it back with a new gasket. Run it a few hours and double check you head bolts and you should be good to go! One thing about those older single cylinders is they are hard to kill. Heres one that I had bought that was smoking like an old steam eng. It ran hard, for about 3 more months before it broke a ring. I was just trying to see how long it would run before i killed all the skeeters in the garden.  Attached Images
Reply:Max, caught you on the PM, heres some pictures   don't have 1 of my oldest WP. With these single cylinder engines it is well worth the price of Snynthetic oil. Get it going and use some cheap oil for a couple or 3 rapid oil changes to get it cleaned out than do a final change and us Mobil 1 or other synthetic. They stand up to the heat of the air cooled engines a little better.,  P.S. before you go sliding that thing around and up and down ramps you should know they weigh in around 500 lbs give or take.  Don't laugh at my boat fuel tank, it is a $19 unit from Cabella's. I found and orginal tank used at a welder repair facility, told me it was mint and he wanted $125 for it, drove 40 minutes to find it was about a gallon and a half and completely rusted inside, Thank you very much but no!    Duane, this is the rust bucket I paid $65 bucks for , it runs and welds but what you see is the good side LOL believe it or not. Attached ImagesLast edited by kolot; 03-06-2011 at 12:13 AM."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:KolotYou paid 65 bucks for that rust bucket? Did I read that right? If so you do nice work and I personaly wouldnt laugh at any " home made " gota get something to work set up. I would have charged the guy my time and fuel to ride up there and look at something that wasnt what was advertised. Just a waste of time when people do that to you.
Reply:If I'm not mistaken, you posted those shots up before.  I was probably as amazed then that it runs and welds in that condition.With the right equipment or access to same a new chassis and sheetmetal could be easily fabricated.  The front panel and louvers may be a little time consuming but doable just the same.  Should make an interesting project. MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:I took very few pics, and with my cell phone no-less.. But heres the Carb after cleaning. Awaiting gaskets before re-assembly.BIG thanks to Duane for showing me where engine info was located. Couldnt get parts without that!![IMG][/IMG] Cosmetically, pretty nice...[IMG][/IMG]Lincoln Power MIG 210 MP ( boat anchor )Lincoln Weld-Pac 100 HDHobart IronMan 230Cutmaster 42Jackson NexGenSumner Ultra ClampsDWM120
Reply:Heck yeah that's in good shape cosmetically!  I wish the SAM 400 I bought last week was in half that shape!
Reply:Kolot, thanks for the heads up regarding oil. Its only 2 qts, so Premium Synthetic wont be a problem..Found on-line manual from Briggs, head torque is 190 in-lbs. Good thing I screwed up all those years ago and bought a in-lbs torque wrench!! Turns out, your supposed to open the head every 100-300 hrs and clean it up.. Manual also has great info on setting up the carb, which will come in handy by next weekend, Im sure...Ill hold-off on grabbing some lead until I see OCV with my meter...One step at a time, hahaRaining hard here... No oil inspection. Head Gasket ordered....Lincoln Power MIG 210 MP ( boat anchor )Lincoln Weld-Pac 100 HDHobart IronMan 230Cutmaster 42Jackson NexGenSumner Ultra ClampsDWM120
Reply:Got it off my truck, thanks to a Kubota.Oil wreaks of gas. Pulled head. Before[IMG][/IMG]After[IMG][/IMG]Cant wait too fire her up, without flooding out!!Lincoln Power MIG 210 MP ( boat anchor )Lincoln Weld-Pac 100 HDHobart IronMan 230Cutmaster 42Jackson NexGenSumner Ultra ClampsDWM120
Reply:Head Gasket in!!Feels like I gained some pop turning flywheel by hand ( dont want to smack anything )Awaiting carb-kit....Oh the anticipation is killing me!!50' of lead in hand...Lincoln Power MIG 210 MP ( boat anchor )Lincoln Weld-Pac 100 HDHobart IronMan 230Cutmaster 42Jackson NexGenSumner Ultra ClampsDWM120
Reply:Carb Rebuilt!!New air filter, and gas lines run, new fuel filter in. Did a compression test just to say "I did it" 105 psi. Not bad for an engine thats as old as my brother.Need 2 qts of oil, ethanol free gas and Ill be hitting the starter!!Lincoln Power MIG 210 MP ( boat anchor )Lincoln Weld-Pac 100 HDHobart IronMan 230Cutmaster 42Jackson NexGenSumner Ultra ClampsDWM120
Reply:Originally Posted by MadMax31S. My Stars, is this thing heavy, bout blew my balls out shoving it up my ramps into my truck..Max
Reply:Originally Posted by weldbeadwhen i got my ranger 8, which is real close in weight, i used  two pieces of 1 1/2" pipe and it slid beautiful..in and out by myself..
Reply:Pics to follow:SHE RUNS!!!Took a few minutes to dial in carb. but  it powers an angle grinder. 228v at 230v plugs. OCV is damn close to nameplate. Auto-idle works as well...All said, Im in 750.00 total for this baby!!Lincoln Power MIG 210 MP ( boat anchor )Lincoln Weld-Pac 100 HDHobart IronMan 230Cutmaster 42Jackson NexGenSumner Ultra ClampsDWM120
Reply:My 2 year old Son approves.New DecalsCannot wait to get my leads hooked up!!!!Lincoln Power MIG 210 MP ( boat anchor )Lincoln Weld-Pac 100 HDHobart IronMan 230Cutmaster 42Jackson NexGenSumner Ultra ClampsDWM120
GMT+8, 2025-12-22 18:05 , Processed in 0.428888 second(s), 18 queries .
