Wire Feeders question
发表于 2021-9-1 00:17:40 | 显示全部楼层 |阅读模式
I’m in the market for a wire feeder, I need a quick education in models and specifications. I’m looking at Miller’s line and will be connecting to a XMT 305 power source. Is the new 75 Series a good unit over earlier models (20 Series)? I’m not working too heavy with the MIG, a lot of mild steel fabrication jobs. I’m looking to spend around $1,000. What is the biggest difference between a S-75S and a S-75DX?
Reply:Go to WWW.MILLERWELDS.COMthis site has used equipment with a factory warrantyI hope this helps you build your Kingdom of welding goodies
GMT+8, 2025-12-22 17:59 , Processed in 0.070093 second(s), 18 queries .
