查看: 13|回复: 0
filling the crater on a vertical up pass
发表于 2021-9-1 00:17:40 | 显示全部楼层 |阅读模式
I know this question might sound basic to some but lets say i'm doing a t-joint in the vertical position. I will always have a crater at the top, back when i was taking welding at school I was always told to run off the plate, but I find when i inspect the t-joint where i ran off still shows sign of a crater.Share some of your crater filling techniques to help a young welder out.
Reply:A couple of small circles then pull off real slow.Stephen
Reply:thanks, I'll try that i use that technique sometimes with the mig
Reply:if your using a mig .....when you get to the end of the weld..stop..hit it again quickstopand do it again(just tap the trigger twice) all before you lift the mask to inspect the weld...zap!
GMT+8, 2025-12-22 19:36 , Processed in 0.091119 second(s), 18 queries .
