Trailer Receiver
发表于 2021-9-1 00:17:39 | 显示全部楼层 |阅读模式
Adam was too busy to finish this one earlier in the week, so...I um, did. The customer wanted a receiver for his trailer. There's an added spacer at the front, also a middle cross-member, and the combo bar itself, so three pieces. http://i176.photobucket.com/albums/w...r/P7120007.jpghttp://i176.photobucket.com/albums/w...r/P7120006.jpghttp://i176.photobucket.com/albums/w...r/P7120001.jpghttp://i176.photobucket.com/albums/w...r/P7120002.jpghttp://i176.photobucket.com/albums/w...r/P7120004.jpgReverse ordered photos'. Under the bed pan, the flat position welds had to be done blind. There was only a few inches for the gun & tip, almost zero visibility. Welding by ear, so to speak. City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:Good stuff, thanksDavid Real world weldin.  When I grow up I want to be a tig weldor.
Reply:Ahh, there's nothing like "point and squirt" welding!Looks like a nice modification there.It seems a lengthy receiver tube, is that so you could attach it in the third spot? Also a bit difficult to see but I figure it stops short of the axle and hence doesn't affect axle travel. Is the extra box section around the end of the receiver for strength or to stop it splitting or flaring?We have a six monthly or yearly vehicle Warrant of Fitness check six monthly after vehicle reaches 5 years old and they look at towbars and receivers and safety chains etc but I've never seen them pull the receiver pin out to check it. That 5/8" pin does all the towing. I've checked my pin and it's showing signs of a little wear and the holes in the hitch tube are wearing too. I'd wondered about adding a couple of collars on the receiver tube and maybe an insert in the inner tube. Has anyone bothered with anything like that, or do you just shell out for a new one?When will the receiver be used? Would it be legal onroad in the US, or only offroad, as it would be here, unless it's a tow truck? Double trailer makes reversing more interesting but I've seen it done successfully."One of the things we have to be thankful for is that we don't get as much government as we pay for." (Charles Kettering)Mitch 180 (NZ)Lincoln SAM-400-220 + ?-400 Fordson Major + 2 x Tractapac Humber 80 + Procut 40 PlasmaMiller Spectrum 375
Reply:Originally Posted by TractapacAhh, there's nothing like "point and squirt" welding!Looks like a nice modification there.It seems a lengthy receiver tube, is that so you could attach it in the third spot? The customer specified exactly what he wanted. He was offered advice which he declined to accept.Also a bit difficult to see but I figure it stops short of the axle and hence doesn't affect axle travel. Good eye, that was part of our advice, use a shorter combo bar. He wouldn't hear of it.Is the extra box section around the end of the receiver for strength or to stop it splitting or flaring?Exactly so!We have a six monthly or yearly vehicle Warrant of Fitness check six monthly after vehicle reaches 5 years old and they look at towbars and receivers and safety chains etc but I've never seen them pull the receiver pin out to check it. That 5/8" pin does all the towing. I've checked my pin and it's showing signs of a little wear and the holes in the hitch tube are wearing too. I'd wondered about adding a couple of collars on the receiver tube and maybe an insert in the inner tube. Has anyone bothered with anything like that, or do you just shell out for a new one? You could, I suppose, repair the fatigued receiver tube, but it may be easier at that point to replace the component entirely.When will the receiver be used? Get this, the customer wanted a place for a removable cooler rack.  Would it be legal onroad in the US, or only offroad, as it would be here, unless it's a tow truck? Double trailer makes reversing more interesting but I've seen it done successfully. Double trailers is not his purpose, if it were, he would have to get a commercial driver's license with an endorsement for pulling "doubles".
Reply:Was that flux-core?  Looks good man, real good!  I'd personally be nervous about welding something like that, but your job looks great!  I guess I don't trust my skills enough to do a hitch hehehehe. well done!Have a Jeep Cherokee?  Click Here!
Reply:Hey, what's up Skwerly?  That is solid wire {ER70S6} and gas {75/25}. How's it going with your project?City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:"We have a six monthly or yearly vehicle Warrant of Fitness check six monthly after vehicle reaches 5 years old and they look at towbars and receivers and safety chains etc but I've never seen them pull the receiver pin out to check it. That 5/8" pin does all the towing. I've checked my pin and it's showing signs of a little wear and the holes in the hitch tube are wearing too. I'd wondered about adding a couple of collars on the receiver tube and maybe an insert in the inner tube. Has anyone bothered with anything like that, or do you just shell out for a new one? You could, I suppose, repair the fatigued receiver tube, but it may be easier at that point to replace the component entirely"i would look at drilling another cross-hole and add a 1/2" bolt. this also takes out most all of the slop.
Reply:Originally Posted by tanglediverThanks for your comments!
Reply:Didn't see anything about a cooler anywhere. Did I miss it? Thanks.Tim Beeker.
Reply:See post #4tanglediver answered: Get this, the customer wanted a place for a removable cooler rack."One of the things we have to be thankful for is that we don't get as much government as we pay for." (Charles Kettering)Mitch 180 (NZ)Lincoln SAM-400-220 + ?-400 Fordson Major + 2 x Tractapac Humber 80 + Procut 40 PlasmaMiller Spectrum 375
Reply:Esky? Chilly Bin? Is that like a cooler?  It's nothing more than an insulated ice box.City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:Originally Posted by TractapacWhat is a cooler, an ice box or an insulated box (Esky In Australia, chilly bin in NZ) or is it like the large Gatorade drinks dispensers you see at football matches?
Reply:Tractapak, over here some call an ice chest (insulated box you put ice in to keep things cool - some run on 12 volt but are kinda pricey) a cooler. The big Gatorade dispensers are usually referred to as a water can. Hope that helps you out.The difference between art and craft is the quality of the workmanship. I am an artist.
Reply:Yep, looked twice, didn't see it. Must be why the wife says I can't find nuthin.Tim Beeker.
Reply:Originally Posted by tnjindYep, looked twice, didn't see it. Must be why the wife says I can't find nuthin.
Reply:Originally Posted by tanglediverEsky? Chilly Bin? Is that like a cooler?  It's nothing more than an insulated ice box.
Reply:Here's 3 insulated coolers.  Made for fish but they work for beer, too.  Sizes are: 54 quart, 94 quart and what some folks call a dead man's chest, 162 quart.  I apologize for the dust and dirt.  But a little soap and water will make them ready for tuna come autumn.WeldingWeb forum--now more sophomoric banter than anything else!
Reply:Originally Posted by tanglediverHey, what's up Skwerly?  That is solid wire {ER70S6} and gas {75/25}. How's it going with your project?
Reply:Yes, It strikes me as an odd place to put something like that. A real rough ride. Be careful opening the beers!
Reply:Originally Posted by SandyIt usually goes something like this; you buy a smaller off road rig because it's easier to get around in the woods, but it won't carry everything you want to take. So you get a small off road trailer to go along with your off road rig, but it still won't carry everything you want to take. So now you add a small rack off the back of your off road trailer that goes with your off road rig, and guess what? Yep, it still  won't carry everything you want to take.
Reply:Originally Posted by 69 chevyHere's 3 insulated coolers.  Made for fish but they work for beer, too.  Sizes are: 54 quart, 94 quart and what some folks call a dead man's chest, 162 quart.  I apologize for the dust and dirt.  But a little soap and water will make them ready for tuna come autumn.
Reply:Originally Posted by DSWWhat no antique Colman steel cooler?
Reply:Originally Posted by 69 chevyI think all the steel Colemans rusted away decades ago.
Reply:It now stores my gunpowder.
Reply:Originally Posted by 69 chevy Made for fish but they work for beer, too.Originally Posted by g33kI always consider mine to be made for beer, but work for fish, too.
Reply:Originally Posted by TractapacI guess it's a matter of priorities. Also, does going fishing have anything to do with catching fish?
Reply:Originally Posted by KingerI still have one!
GMT+8, 2025-12-22 18:03 , Processed in 0.091010 second(s), 19 queries .
