Ideas for Mounting a High Lift Jack inside a Suburban
发表于 2021-9-1 00:17:32 | 显示全部楼层 |阅读模式
I want to make a mount to hold my high lift jack inside the suburban so it does not rust etc...Anyway you guys got ideas of where it could be mounted? Maybe even a interior roof mount? Do you think the roof metal will hold up over time?
Reply:Originally Posted by goodoleboyI want to make a mount to hold my high lift jack inside the suburban so it does not rust etc...Anyway you guys got ideas of where it could be mounted? Maybe even a interior roof mount? Do you think the roof metal will hold up over time?
Reply:Not on the roof.In the bed area fer sure.Pics of the inside of the burb?Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:I would think the best place to mount the jack inside a Suburban would be to the rear seat  brackets . This should keep it accessible  yet out of the way.
GMT+8, 2025-12-22 19:37 , Processed in 0.108112 second(s), 18 queries .
