Small engine aluminum carb
发表于 2021-9-1 00:17:31 | 显示全部楼层 |阅读模式
One of my customers dropped this off yesterday.  I said I dont' know if I can weld it or not.  He left.  I hit one of the pieces with the tig to see if it was aluminum and not zink or what ever.  It looked OK, so I gave it a shot.  I tried pulse and it didn't work for sh*t, so I turned it off.  I was about 75 amps give or take.   43% + wave balance, 150 Hz because that is where it was last time, 15 cfh argon, 1/16" 5356.  I have no 1/16 4043 or I would have used that.  Red or gold 3/32" tungsten, I used many.  I can't tell the difference.The hole is for fresh air to boost fuel economy The fuel line fitting is 1/4" for scale.I rubbed my files with soapstone, but they still loaded up.  I kept cleaning them with a file card, but....I didn't think I could do it, musta been from welding those coke cans.  Took a little over 1/2 hour.  DavidLast edited by David R; 07-30-2008 at 09:05 PM.Real world weldin.  When I grow up I want to be a tig weldor.
Reply:Let us know if it works or not? I didn't think that could be done either, on one so small.Miller Thunderbolt 225Millermatic 130 XPLincoln HD 100 Forney C-5bt Arc welderPlasma Cutter Gianteach Cut40ACent Machinery Bandsaw Cent Machinery 16Speed Drill PressChicago Electric 130amp tig/90 ArcHobart 190 Mig spoolgun ready
Reply:Jeez, I'd have tossed it in the trash & found one similar. Looks like you pulled it off though, good work!Miller EconotigCutmaster 38Yes ma'am, that IS a screwdriver in my pocket!
Reply:Good job David. Thanks for the pics, now I have something else I'm not afraid to try. What the heck did that guy do to break it that bad? I think welding coke cans teaches more than welding coke cans. 9-11-2001......We Will Never ForgetRetired desk jockey. Hobby weldor with a little training. Craftsman O/A---Flat, Vert, Ovhd, Horz. Miller Syncrowave 250
Reply:Originally Posted by Craig in DenverI think welding coke cans teaches more than welding coke cans.
Reply:Looks pretty good!If you have a small ( 1/2 " ) sanding drum for a die grinder, you might smooth the inside passage a bit and tell him to cover any pits/rough spots with epoxy before installing it, just to keep any turbulence down.
Reply:Originally Posted by Oldiron2Looks pretty good!If you have a small ( 1/2 " ) sanding drum for a die grinder, you might smooth the inside passage a bit and tell him to cover any pits/rough spots with epoxy before installing it, just to keep any turbulence down.
Reply:So, did it run?Roger
Reply:YES it ran fine, the customer called and said it fit just as it should.David Real world weldin.  When I grow up I want to be a tig weldor.
GMT+8, 2025-12-22 19:32 , Processed in 0.075563 second(s), 19 queries .
