esab mm260?
发表于 2021-9-1 00:17:26 | 显示全部楼层 |阅读模式
Does anyone have any thoughts on an esab multimaster 260 cc/cv stick,tig,arc?Good machine?
Reply:Couldnt speak from first hand experience with this machine, but esab is a good company, been around a while.  They dont have quite the exposure that lincoln and miller have.  However, they are good brand.  I would think this machine prolly can hold its own.  The 260 amp size I would think would make it very suitable for most folks.IF it Catches...Let it Burn
Reply:Originally Posted by daveDoes anyone have any thoughts on an esab multimaster 260 cc/cv stick,tig,arc?Good machine?
Reply:DaveI would really consider buying a Mig Machine and a Tig Machine.I know welding equipment is relatively inexpensive.  You could add two machines to your Kingdom of Wealth.Get a Miller Matic DVI or a 210 and then a Miller Syncrowave 200 or 250Can you get some work to off set the cost by having weekend work pay for the machines ?May your Kingdom grow and be passed to the next generation of welders
Reply:i  weld just about anything i can.I dont weld for money anymore except for the occasional "favors"
GMT+8, 2025-12-22 19:31 , Processed in 0.072215 second(s), 18 queries .
