wire feeder for smaw machine
发表于 2021-9-1 00:17:26 | 显示全部楼层 |阅读模式
I have a 1983 Lincohn Ideal arc 250 smaw and tig welder. Can I put a wire feeder on this machine and what do you suggest? It is a cc machine so will I need a voltage senceing type unit? thanks in advance for any info.  Kevin
Reply:you can do this with yes a voltage sensing feeder such as ln 25 or suitcase vsIF it Catches...Let it Burn
GMT+8, 2025-12-22 19:31 , Processed in 0.070391 second(s), 18 queries .
