Victor 315
发表于 2021-9-1 00:17:23 | 显示全部楼层 |阅读模式
My father in law gave me a Victor 315 torch handle with a Victor cutting head Mod # CA1050, gauge's and hose. He said he has had them for a long time. From what I have read in other threads this will work fine for cutting once I replace o-rings and clean it up. Is there a way to date these by the serial number? Any other info you would like to add about his, feel free to do so. Thanks.Cheers,Jim
Reply:if you go to the victor site they should be able to help you.  believe they are now part of thermadyneIF it Catches...Let it Burn
Reply:I got a really old set from a friend going out of business. I took it to Airgas. They sent it out to Victor and it came back better than new. You might want to check that out. I paid 80bucks to rebuild a 300dollar torch set. Not a bad deal if you ask me.
GMT+8, 2025-12-22 19:50 , Processed in 0.093643 second(s), 18 queries .
