查看: 13|回复: 0
cheapest place to buy mig wire
发表于 2021-9-1 00:17:22 | 显示全部楼层 |阅读模式
where's cheapest place to buy mig wire i just went to sears and a 2lb roll is 14.99
Reply:Not Sears, Lowes, H-D or any of the big box retailers.    Go to a place that sells welding gases.    Around here, they sell wire and other consumables at commodity prices.  My local supplier, Albrights, has small spools of mig wire for less than half what Lowes is offering.There are no small projects
Reply:i think ive payed between $1-$3 per pound, depending on the size of the roll. dont buy from the big stores, buy from mom and pop welding supply shops, or at least from welding specific shops.much better price. not to mention they know welding, and welding supplies.
Reply:If I need it now, I buy from tractor supply.  In my area, welding supply places are 9-5 operations...I can never get by in time to see what their prices are.  TSC is cheaper and has fresher welding supplies than big box alternatives.I dont use small rolls much, but http://store.cyberweld.com/  has free shipping, but I don't really know how thier prices compare with what you have seen.  Might check that out...not an endorsement, just FYI.Smithboy...if it ain't broke, you ain't tryin'.
Reply:WWW.AIRGAS.COMI hope this helps you with the knowledge you seek to help build your Kingdom
Reply:One note,      There really is a difference in arcing characteristics of different brand wires, especially in the low voltage ranges of .023 and .030 wire.       Better brand wires are really worth a little more. Any major brand s-6 (if you are short circuit welding) wire should suffice. We have done tests of different brands with the small track mig and noted major differences in weld fusion especially in some of the off brand products. (no I won't name brands )      If you are running flux cored wire the difference is even more striking (no pun intended)regardsLast edited by ZTFab; 12-09-2010 at 05:23 PM.
Reply:At my dads shop we buy from a gas,welding distributer up to a couple years ago we bought the indavidual 60# boxes going through one or two a week then we found out that if you buy in bulk its allot cheaper! I think that we saved over $2000  a year by buying a pallet of the 60# boxes.Which might be a bit off youre question if youre buying wire from Sears.Sorry Bapnbird
Reply:Try buying the biggest spool of wire you can fit into your machine. If you use SS, or regular rod, a 10lb spool is maybe only 1/2 again as expensive as a 2 lb spool. And, a 30lb spool is relatively giving you a lot of extra wire for a given price. You may need an adapter to fit a bigger spool, but you will save money in the long run. And, the nice thing.... wire on a spool is still good in 6 months, it doesn't grow mold. Unles you let it rust. That is not so good.
Reply:how many metres of wire in one roll?
Reply:lurkin'
GMT+8, 2025-12-22 19:46 , Processed in 0.087408 second(s), 18 queries .
