3k trailer tongue winch install
发表于 2021-9-1 00:17:16 | 显示全部楼层 |阅读模式
Last week, I rewired this car carrier trailer's tongue with a seven-way connector and break-away switch to replace the four-pin-flat.http://i176.photobucket.com/albums/w...r/P8110002.jpg This week, the customer wishes to have a winch added with a wet-cell battery for power. So, first we hatched an idea for a mouting plate, which came in the form of a left over fifth wheel component. I added a gussett underneath for strength.http://i176.photobucket.com/albums/w...r/P8110003.jpgJust a couple end cap plates will finish the base plate.http://i176.photobucket.com/albums/w...r/P8110004.jpgOK next, some connecting angle for a frame to hold a battery is called for. They are just visible on the opposite side from my foot.http://i176.photobucket.com/albums/w...r/P8120006.jpgFollowed by the first cross member.http://i176.photobucket.com/albums/w...r/P8120007.jpgAnd next post...City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:The last cross member with two connectors between.http://i176.photobucket.com/albums/w...r/P8120008.jpgPaint and put the winch and box in place.http://i176.photobucket.com/albums/w...r/P8120009.jpgThat's it, everything tested ok, so just button it all down and ship it!http://i176.photobucket.com/albums/w...r/P8120011.jpgCity of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:Sweet.  Nice piece of engineering and photo series.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Where'd you hide the 1st battery for the break away, underneath??  "Course you don't need two batts now tho.
Reply:[QUOTE=tanglediver;206504]The last cross member with two connectors between.Paint and put the winch and box in place.That's it, everything tested ok, so just button it all down and ship it!'Looks 'nice'' ......by testing do you mean testing that winch, stalled out for dead, full pull, to seehow much those light angle crossmembers will flex from the leverage applied by the winch?Blackbird
Reply:Sandy, we knew it would be coming back after the customer picked up the winch. Only the deep cycle battery was used. I tried the movie mode in the camera today. Here is a double test, the winch and the camera![ame]http://www.youtube.com/watch?v=3VeDHwMQ9tU[/ame]City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:Originally Posted by dave powelson'Looks 'nice'' ......by testing do you mean testing that winch, stalled out for dead, full pull, to seehow much those light angle crossmembers will flex from the leverage applied by the winch?
GMT+8, 2025-12-22 19:47 , Processed in 0.528614 second(s), 18 queries .
