rig project
发表于 2021-9-1 00:17:13 | 显示全部楼层 |阅读模式
here is some photos of the truck and the leveling jacks for my old drill rig that I built. the rig was a 5th wheel and very slow to set up. They are not real pretty but a little paint will make a big difference. I found this forum when I started this project and got a lot of advice from everyone so thanks
Reply:I must be getting old. I can't see the pictures.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:Originally Posted by Joker11I must be getting old. I can't see the pictures.
Reply:Originally Posted by idacalhere is some photos of the truck and the leveling jacks for my old drill rig that I built. the rig was a 5th wheel and very slow to set up. They are not real pretty but a little paint will make a big difference. I found this forum when I started this project and got a lot of advice from everyone so thanks
Reply:Idacal, that rig is a blast from the past. At least from what I know anyway. Pretty neat. As a young guy growing up the old cable rigs were being aced out by the new "rotory" rigs. I remember seeing small rigs set up and hammering away for days on end on a hole. I was always amazed. Nice work.
Reply:I cut it apart and cleaned it all up and welded it up again it worked out okay it still drags a little and Im building a another housing for it but it is working. It will drill 24" to about 1800' but I dont go that deep we mainly use them for bailing out irrigation wells and installing surface casing through the gravel for the mud rotary rigs 24" 80' holes. So a fast set up is a requirement. Wth the way its set up i can be ready to work in 2 hours rather than 9 the way it was.
GMT+8, 2025-12-22 19:47 , Processed in 0.093443 second(s), 18 queries .
