Trailer gate
发表于 2021-9-1 00:17:12 | 显示全部楼层 |阅读模式
A buddy of mine has asked me to weld up a drop down gate for a small utility trailer thatis mainly used to haul a four wheeler.  The gate will be about 4 feet tall and 6 feet wide and will be used as a loading ramp.  What kind of hinges would be the best for this?  Thanks for the help.
Reply:I see a lot of those made with pipe and round bar, sized to fit the job. Some of them I've seen were better than 1" in diameter for heavy duty stuff.City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:A good heavy duty hinge can be made out of 3/4 inch schedule 40 pipe and 3/4" solid rod. Three feet of pipe and three feet of rod. Cut the pipe into 4- 4" pieces and 2- 6" pieces. Cut the rod to 18". Place 1- 4", 1- 6", and 1- 4" pipe on the rod and weld the 6" piece to the trailer gate where you want it. Do the same on both ends of the gate. Hold the gate with the hinge against the trailer and tack the 4" pieces to the trailer leaving a 1/8" gap between each piece of pipe. Tack all the pieces and check for proper operation before welding solid. A heavy cotter pin can be put into each end of the rod to keep it in place.
Reply:i agree with the other replies. do make the gate removeable though for you never know when you might need that extra room for loading longer things on the trailer.
Reply:tcb..... Here is a link to a trailer gate mod I did some time ago. not the best pictures of the hinge but i think you can see enough to help you out.http://weldingweb.com/vbb/showthread.php?t=12497there are pictures of another trailer also with a 4 ft folding gate done by another member that might be good for your project...later and have fun.Bruce   People are more violently opposed to fur than leather because it's safer to harass rich women than motorcycle gangs.  Unknown Pro Mig 175Hyphertherm 600Lots of toys at work
Reply:Here in washington state, some of the steel supply houses carry things like that. Pacific steel is one. You may check your local supply house for steel hinges.Bill
Reply:Thanks for the replys.  This should get me going in the right direction.
GMT+8, 2025-12-22 19:46 , Processed in 0.095027 second(s), 18 queries .
