Swings
发表于 2021-9-1 00:17:11 | 显示全部楼层 |阅读模式
These are from an old food stand on the canal.  The owner asked me to fix them.  These are not the only ones.  Here I stuck a 1 1/4" pipe through until it came out his Cut the tail down to the good stuffI trimmed all pipe, and welded both sides of the front pipe to the 1/14".  Galvanized kept coming out from the inside of the pipe.  I know I had it hot enough. Attached ImagesReal world weldin.  When I grow up I want to be a tig weldor.
Reply:These welds were all tigged in position.  Exhaust tube and the last piece of 1 1/4"Nuttin fancy today.Still switching between ER70S-2 and -6.  I think -6 wins  it flows better.3/32 tungsten (about a dozen), machine set on 100 amps, 15 cfh argon, #5 cup.DavidLast edited by David R; 08-18-2008 at 09:28 PM.Real world weldin.  When I grow up I want to be a tig weldor.
Reply:Neat little job, nice work.I like your new sig. It's true too.  Most folks only show the stuff that was done under perfect conditions, with perfect fitup, etc...Miller EconotigCutmaster 38Yes ma'am, that IS a screwdriver in my pocket!
Reply:It would appear you're as much a veterinarian as you are a weldor.  From rock 'hounds' to 'horse' swings!  Nice work.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:thats real a real butt weld lolNothing Ever Got Done By Quitting, Never Give Up.
Reply:Originally Posted by Doug247thats real a real butt weld lol
Reply:i would hate to be that horse with a pipe stuck where it is.
Reply:Originally Posted by David RThese are from an old food stand on the canal.  The owner asked me to fix them.  These are not the only ones.  Here I stuck a 1 1/4" pipe through until it came out his Cut the tail down to the good stuff
Reply:Methane shielding gas - that's got to be a first!MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2025-12-22 21:16 , Processed in 0.103521 second(s), 18 queries .
