does any one know
发表于 2021-9-1 00:17:11 | 显示全部楼层 |阅读模式
just wondering what the bit of metal that makes the face/ nose of this pighttp://i306.photobucket.com/albums/n.../piggyb_sm.jpg
Reply:bit of rusty metal!
Reply:it rusts like steel  I would just hit it with grinder and watch the sparks.
Reply:I think he was wondering what the piece may have come from originally, not what type of metal it is.Miller EconotigCutmaster 38Yes ma'am, that IS a screwdriver in my pocket!
Reply:looks like a peice of tube or maybe an axle hub.
Reply:It Is Half Of A Spool That Goes Between Disc On A Disc Plow That You Pull With A Tractor.
Reply:Originally Posted by TEDTWOFEATHERSIt Is Half Of A Spool That Goes Between Disc On A Disc Plow That You Pull With A Tractor.
Reply:seen one today looked like that behind my grandfathers barn. was back there lookin for some trailer part in his scrap pile. not sure as to what it goes to though but would have to agre with the other post for it makes the most sence with all his farm gear and everything
Reply:Originally Posted by Joe HI think he was wondering what the piece may have come from originally, not what type of metal it is.
Reply:ill should have no problem finding one aorund our farm then if its of a disc plow
Reply:You Can Cut One In Half Or Get One That Is In The Section That Has The Bearing. There Are Two A Long One And A Short One.
GMT+8, 2025-12-22 19:46 , Processed in 0.096348 second(s), 18 queries .
