gate posts and work for a salon
发表于 2021-9-1 00:17:10 | 显示全部楼层 |阅读模式
the posts are for a driveway gate, should be installed next week, they are 10' overall with 3' in the ground 6/6" 3/8 tube as a core with 1/4" plate to form the shape. and heavy....around 550lb each.... fun to get off the table.... for the salon we did the scroll work on the wall and the scissors the scroll work is all made in house out of 1/4"/1" steel with gilders past for the highlights the scissors are 3/4" plate that we had plasma cut and ground to shape (edges rounded and angles cut in ) over all a fun little project Attached ImagesHeat it and Beat it!!!http:www.Fallinghammerproductions.com
Reply:That rocks it looks really good.I carry guns because cops are too heavy. .. ..-.   -.-- --- ..-   - .... .. -. -.-   .... .- .-. -..   . -. --- ..- --. ....   -.-- --- ..-   -.-. .- -.   ..-. .. --. ..- .-. .   .- -. -.-- - .... .. -. --.   --- ..- -
Reply:Excellent suff. Especially the name "Dragon breath".About getting off the table - I still think that you should call one more guy...
Reply:Awsome work...kinda gives a whole new meaning to don't run with scissors...drive with scissors?--Wintermute"No man's knowledge here can go beyond his experience." - John Lockewww.improvised-engineering.comManufacturer Agnostic:Blood----------Sweat---------Tears----|------------------|----------------|----Lincoln Red, Miller Blue, Esab Yellow
Reply:it took two of use to get them on the cart from the welding table..... but when the install guy came to pick them up it took 4 of us to get them off the loading dock and on to the truck. I got some odd looks driveing down route 84 in rush hour trafic with that in the back of my truck... got to be kind of fun to see the double takes.Heat it and Beat it!!!http:www.Fallinghammerproductions.com
Reply:Those scissors do look like a fun project. Are they as sharp as they look? They look kind of dangerous. Nice work! Oh yeah, what kind of coating did you use to prevent the scissors from rusting?Lincoln AC/DC 225/125 Stick Linde HDA-300 MillerMatic DVI MIG Miller Dynasty 200DX Hypertherm Powermax 1000
Reply:great project looks great Creative metal Creative metal Facebook
Reply:That looks greatWhat is the significance or symbolism of the scissors?A good guess is better than a bad measurement
Reply:Signifigance is that scissors cut hair.OP said it was for a Salon. I know what you Aussies are like though..... You read the word "Salon" and your natural attraction to partying, drinking, and having a good time distorted the word so you saw what you wanted to see.. "Saloon"    I love those gate posts. They would be great for the idiots that keep knocking mine down in front of the shop.
Reply:Originally Posted by Ryan McEachernSignifigance is that scissors cut hair.OP said it was for a Salon. I know what you Aussies are like though..... You read the word "Salon" and your natural attraction to partying, drinking, and having a good time distorted the word so you saw what you wanted to see.. "Saloon"    I love those gate posts. They would be great for the idiots that keep knocking mine down in front of the shop.
Reply:You do good work! Those scissors look to real!Miller Thunderbolt 225Millermatic 130 XPLincoln HD 100 Forney C-5bt Arc welderPlasma Cutter Gianteach Cut40ACent Machinery Bandsaw Cent Machinery 16Speed Drill PressChicago Electric 130amp tig/90 ArcHobart 190 Mig spoolgun ready
Reply:we used a  product called permalac it is rated 10 years exteror in salt spray. the only isue I had with it was due to the humidity the day I coated it (a bit of clounding), even so it seems to be protecting the finish well.MPLast edited by mpmetal; 08-02-2008 at 02:06 PM.Reason: re read then post!Heat it and Beat it!!!http:www.Fallinghammerproductions.com
Reply:Impressive stuff.  Are there any code issues with the pointed scissors?Looking forward to seeing the posts installed.
Reply:Hey, very slick!!  Those scissors rock!  "Sharp" idea!Have a Jeep Cherokee?  Click Here!
Reply:Originally Posted by SkwerlyHey, very slick!!  Those scissors rock!  "Sharp" idea!
Reply:it fell under the code for signs. over all hight and mounting were the only codes we found on it.(at lest that is what the inspector said) also it isn't as sharp as it looks the edge is 3/8 at the base and widens to about 5/8 by 1/2 at the point.MPHeat it and Beat it!!!http:www.Fallinghammerproductions.com
Reply:Nice workThanks for the pic'sMiller DVI2Lincoln Precision Tig 225Thermodynamics Cutmaster 38Everything else needed.
Reply:as requested,these are just in primer for now as the gate should be going in next month. Attached ImagesHeat it and Beat it!!!http:www.Fallinghammerproductions.com
Reply:Originally Posted by BurnitThose are some corny jokes, but really those scissors are shear genious.Ok thats bad
Reply:Those sissors are f*#ken awesome!!!!Not that I'm a hairdresser but I want a pair...what reason...I have none.
Reply:Very very nice!!!And then, after so much work...... you have it in your hand, and you look over to your side...... and the runner has run off. Leaving you holding the prize, wondering when the runner will return.
Reply:I would like to see the gates after they are up!  Nice work by the way
Reply:just some bits and peices we installed today. there is a granite top going on it tomarrow . it is about 8 and 1/2 feet over all Attached ImagesHeat it and Beat it!!!http:www.Fallinghammerproductions.com
Reply:Nice work. Looks like a fun job. Is the salon inside a house? It looks like a kitchen and living room in the background.Lincoln AC/DC 225/125 Stick Linde HDA-300 MillerMatic DVI MIG Miller Dynasty 200DX Hypertherm Powermax 1000
GMT+8, 2025-12-22 19:47 , Processed in 0.072288 second(s), 18 queries .
