Wood Spltter Wedge
发表于 2021-9-1 00:17:03 | 显示全部楼层 |阅读模式
What grade steel would you recommend?  I am going to build a new wedge + 4-way for a friend of mine.  It gets used pretty heavily and will be splitting oak, hickory and other hard species.If you have any pictures of wedges you have built or have please post them.  I am open to suggestions.  The splitter is a vertical with wedge mounted on the cylinder.I will post pictures of it when I get it done.
Reply:this one is a bit extreme   100% machined and replaceable.  I wouldnt go 4 way if your cutting big rounds.    to hard to cut small pieces when you need em   i cancut any size i need w this onebtw  i think its A-36Ill get close ups today Attached Images“I'm going to do the thing that God put Galen Beasley on this Earth to do:Have Salon quality hair and weld.Nothing like a good cup of coffee and the smell of 6010 burning in the morning. 971-204-3444 cell API ASME Structural NDT and Repair
Reply:i made both of these wedges using A36. straight wedge is 1" thick x 8" tall.  the splitting angle is 15*.  it goes back from the leading edge 1 1/4".  the 4 way is all A36 1/2".  the 2 wings should be angled toward the leading edge.  the 4 way wedge is able to split oak rounds up to 8".dave. Attached ImagesLast edited by rvpc; 03-29-2011 at 11:05 PM.Reason: add text
Reply:and a few more. Attached Images
Reply:Originally Posted by Scott YoungWhat grade steel would you recommend?  I am going to build a new wedge + 4-way for a friend of mine.  It gets used pretty heavily and will be splitting oak, hickory and other hard species.If you have any pictures of wedges you have built or have please post them.  I am open to suggestions.  The splitter is a vertical with wedge mounted on the cylinder.I will post pictures of it when I get it done.
Reply:Here's some pics of the wedge and splitter.  Its made to run off any hydrolic pump. Even the Peterbuilt but mostly use the skidsteer.  Has a 50 ft. retractable hose Attached Images“I'm going to do the thing that God put Galen Beasley on this Earth to do:Have Salon quality hair and weld.Nothing like a good cup of coffee and the smell of 6010 burning in the morning. 971-204-3444 cell API ASME Structural NDT and Repair
Reply:Few more pix.  those two pipes welded on the plate in the 3rd pic are the beverage holders.   they were tacked on the veritcal ibeam.   That cylinder popped it right off when splitting big rounds.Go big or go home lol Attached Images“I'm going to do the thing that God put Galen Beasley on this Earth to do:Have Salon quality hair and weld.Nothing like a good cup of coffee and the smell of 6010 burning in the morning. 971-204-3444 cell API ASME Structural NDT and Repair
Reply:here one I just made  75 lbs A36Thermal Arc T-Bird 270 Amp gas welder Thermal Arc Pro Wave 185PowerArc 200 Riland 60 PlasmaMiller suitcase 12vs wire feeder, 180 Amp Diesel Welder GenEllis 1600 bandsawImig 205 Mig,Eastwood 250 migLincoln 250 G9 Pro gas Weldanpower
Reply:What are the benefits / drawbacks to using a wedge on the ram vs. a stationary wedge?"Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:If A36 is all yall are using then I will not worry.  I will post up soon.
Reply:Originally Posted by Stick-manWhat are the benefits / drawbacks to using a wedge on the ram vs. a stationary wedge?
Reply:a few of the benefits of my splitter in having the wedge attached to the ram are:the ability to use horizontal or verticalcontrol of the splitting edge [safety]removal of wedge for maintenance or rework.iv'e had to remove it twice since it was built.  once to build the 4 way wedge.  and once to add the angles on the sides [to increase splitting efficiency].dave
Reply:I have never used one but I would think a stationary wedge at the end would let the wood pile up behind the splitter and a moving wedge would pile it up in the middle of the splitter. Using the splitter horizontally of course. I think it would be easier to have it with the stationary?????"Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:I like the stationary wedge it allows you to keep splitting without having to move the pile. as you split the pile is pushed away from the machine instead of  falling at you feet. At first i like the idea of a wedge on the cylinder for vertical use, but i find it much easier to lift a log up and work standing upright at the machine than being hunched over dealing with split pieces. there are also ways to make the splitting wedge removable even if it is in a "fixed" position.  two thumbs up for the fixed wedge (four way at that)
Reply:This is a question better asked in a group dealing with computers.  I am better prepared to discuss the merits of 6011 versus 7014 than something about your windows.  Shutters are more practical than curtains.I offer three choices: Good, Fast, & Cheap. You may pick two.Hobart AC/DC StikMate LXHarbor Freight AD HoodHarbor Freight Industrial Chop SawDeVilbis 20 Gallon, 5 HP Compressor
Reply:This is a question better asked in a different group. My knowledge of windows technology is limited.In my opinion Shutters are better than curtains.I offer three choices: Good, Fast, & Cheap. You may pick two.Hobart AC/DC StikMate LXHarbor Freight AD HoodHarbor Freight Industrial Chop SawDeVilbis 20 Gallon, 5 HP Compressor
Reply:Originally Posted by nadogailThis is a question better asked in a group dealing with computers.  I am better prepared to discuss the merits of 6011 versus 7014 than something about your windows.  Shutters are more practical than curtains.
Reply:here is a splitter i built yrs ago. hooks to the tractor and runs off it's live hydraulics. the wedge is 1" thick with 2"x3/8" angle welded cross. the pic shows the wedge in the retracted position between the (for lack of anything better to call them) knock off plates. you will want those encase the log gets stuck on the wedge. just raise it up and the plates will knock it loose. this splitter handles 2 foot diameter Almond tree rounds with ease which when compared to oak makes the oak look like pine for hardness. i have used it on valley oak round as big as 4 foot diameter. try that with your horizontal splitter. good luck unless you have a hydraulic lift for the log. Attached Images225NT bobcatAEAD200LEScott 125mm175, mm252 w 30A, PT225mm211, TA 181iHyper Therm 380, cut master 529100X & XX, Digital Elite6 Victor setssmith little torch, meco midget kalamazoo band sawsteel max saw evoulution circular saw
GMT+8, 2025-12-22 19:51 , Processed in 0.104021 second(s), 18 queries .
