Oxy-Acetylene Nozzel sizes Metal thickness and Fuel & oxy recommended settings
发表于 2021-9-1 00:16:36 | 显示全部楼层 |阅读模式
Hi Folks, I am new to gas welding and would really appreciate some guidance on nozzel sizes relative to metal thickness and appropriate fuel and oxygen settings. I am using Murex regulators/combi torch and intend welding/cutting mild steel? Fuel type is Oxy-Acetylene. Initially I will be working on 3mm mild steel but may progress to 6mm. I have completed 120 hours of both Tig and Arc welding and 60 hours of Mig welding and am completing my 60 hours of gas welding.Any help or charts would be greatly appreciated.Burnt fingers.
Reply:Tip sizes are specified by the manufacturer of the torch, as most manufacturers have their own specific tip sizes. A number 1 tip by Victor may be a totally different flame size than a number 1 tip by Harris, or Smith, or Murex. Look up Murex for a tip chart or cutting guide. Your instructor should be able to find comparison charts if available also. City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:http://www.murexwelding.co.uk/murex/...-Equipment.cfmClick on welding nozzles.   I noticed that the sheet quoted flows in liters per hour, but did not provide corresponding pressures.   Not sure how your gauges are calibrated, in the USA it is psi, pounds per square inch.The link below may be better.  Click on oxy-fuel gas welding.http://www.murexwelding.co.uk/gb/en/support/index.cfmRichardSculptures in copper and other metalshttp://www.fergusonsculpture.comSyncrowave 200 Millermatic 211Readywelder spoolgunHypertherm 600 plasma cutterThermal Arc GMS300 Victor OA torchHomemade Blacksmith propane forge
Reply:Many thanks Richard your link provided very useful information in relation to my query.Best wishes,Barry (burnt fingers).
Reply:Many thanks Tanglediver, your suggestion proved very helpful.Best wishes,Barry (burnt fingers).
Reply:Originally Posted by tanglediverTip sizes are specified by the manufacturer of the torch, as most manufacturers have their own specific tip sizes. A number 1 tip by Victor may be a totally different flame size than a number 1 tip by Harris, or Smith, or Murex. Look up Murex for a tip chart or cutting guide. Your instructor should be able to find comparison charts if available also.
GMT+8, 2025-12-22 19:51 , Processed in 0.095808 second(s), 18 queries .
