I just got a new Linccoln arc 225 stick welder.So I ran 220 to the garage. When I test the outlet I get 110 from each hot. This means I have 220 right?If so then why is it when I plug in the welder and turn it on nothing happens?Tried to strike an arc and nothing. There is no noise as I would have expected a low humm. NOTHING?Could there be something wrong with a brand new welder? Or is there something I am missing?Thanks in advance for all the help.
Reply:Originally Posted by huntersI just got a new Linccoln arc 225 stick welder.So I ran 220 to the garage. When I test the outlet I get 110 from each hot. This means I have 220 right?If so then why is it when I plug in the welder and turn it on nothing happens?Tried to strike an arc and nothing. There is no noise as I would have expected a low humm. NOTHING?Could there be something wrong with a brand new welder? Or is there something I am missing?Thanks in advance for all the help.
Reply:Thank you for the extremely quick reply. You were correct I just used the wrong double breaker.After getting the correct breaker it only took approx 2 min to fix the issue.The welder works great now.Again THANK YOU!
