Tacoma spindles
发表于 2021-9-1 00:16:31 | 显示全部楼层 |阅读模式
All I have at my house right know is 308 filler rod do think it will work. I usally use Super Missile rod @ work which pretty much is 309I'm making drop spindle for my truck..Strive For Perfection
Reply:Whats the spindle made of in the first place?That will be a big help in an answer...I'm going for a walk..Be back later.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:It should work ok.  Stick,tig or migSMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases.  There all here. :
Reply:Ask Max what he used to weld to the Taco spindles he did?Lincoln PowerMIG 215XTLincoln Precision TIG 225Hypertherm 300
Reply:I'm not sure what there made out of its seem like i could just use 70s-2Strive For Perfection
Reply:Originally Posted by Twisted MinisAsk Max what he used to weld to the Taco spindles he did?
Reply:Spindles should be forged.  So they are good steel. David.Real world weldin.  When I grow up I want to be a tig weldor.
Reply:I would like to weld then machine  a ring to my forged steel stubaxles to allow for a bigger cv joint on my off road car. I am planning on  a  3'8" thick mild steel ring 3/4" wide. I am planning on a slow cool down. What would you use for rod/wire?Some things can't be carried in a tool bucket.
GMT+8, 2025-12-22 21:02 , Processed in 0.148401 second(s), 18 queries .
