Got Any Little Ones??
发表于 2021-9-1 00:16:30 | 显示全部楼层 |阅读模式
Kind of a neat thing to keep the calves, or other small stock from knockin' over the bucket.Ok, Ok............ I got way too much time on my hands.  It was Winter after allHaven't figgered a way to keep 'em from crappin' in the bucket, but I'm workin' on it!!!! Attached Images
Reply:Holy Chit!  You don't weld in that hay do ya?DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:DSee the garden hose layin' there?  Grinder is the worst.  Working on doin' a bevel or somethin', and you don't really look around to see what's goin' on to yer right side.  Smell of smoke generally clues ya in to the sittuation.  Garden hose, water applied to area liberally before doin' what ya got to do,  A GOOD DAY.  Alternative............. Make sure ya gave a good donation to the volunteer fire department last time the were out with the empty boots.D
Reply:Yep that looks like farm country to me.  I could tell you the smell of burning grass or hay from a mile away.  Lord knows I have stomped out a many grass fire working on equipment in my day.I'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
Reply:Originally Posted by farmersammHaven't figgered a way to keep 'em from crappin' in the bucket, but I'm workin' on it!!!!
Reply:hey 69chevy that gave me a clue u would have to reverse it but it would work farmersamm how big are your calves cuz u could make it so there backend is 2 or 3 inches higher than the guard it should work like a charmlet me kno if that helped any later agwelderold skool idealarc welderEsab multi tool Milwauake 7inch angle grinder the best of all tho the oxyacceteline set up
Reply:Originally Posted by David RHoly Chit!  You don't weld in that hay do ya?David
Reply:you cant keep em from crappin the bucket or each other..if you want em clean use acetone i guess....
Reply:Dang farmer!  I know you said you smoke alot but there's got to be a pack and a half of butts laying there next to that bucket rack.  You sure you know how those fires are startin'?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2025-12-22 20:59 , Processed in 0.128901 second(s), 18 queries .
