New to this forum with a question.Has anyone welded on a torsion spring? It's a 5/16 diameter wire spring? How about any spring and what results on the spring.Did it work or did it break?
Reply:You can weld it but it wont ever be a spring again.Two turn tables and a microphone.
Reply:I told them it will probably break, but the alternative was not much more attractive to them, so I gave no warranty on the labor and this is how it looked after putting the two halves back together with oxyacetylene. Attached ImagesCity of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:It needs to be replaced. By heating it to weld you have changed the temper.Springs are hardened (Heated to non-magnetic and quenched) and then Tempered by reheating at a lower temperature. Springs are tempered at approximately 350-375 degrees. any time you heat past 350-375 degrees you ruin the piece.It may not break but it will not perform.This is a VERY generic explanation but it covers the basics of why welding a spring will always ruin it.
Reply:True.City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:Thanks for the help everyone.I will go with plan B
Reply:by reheating it and letting it cool you have "normalized "it in a small area.did u use a filler!!. i make chisels and punches all the time with leaf and coil spring.its usually,depending on the use of the spring,alright to weld. the haz is where ull have a prob if any.should be alrightlincoln weld pak 100 hdlincoln ranger 225gxt ac/dcoxy/acetylenepuroxcw202 victor fc100harris model 85harrismodel 16oxweld w24roxweld w17
Reply:if you dumped water to cool it off at red heat ud be in trouble as it would be at max hardness then it would need another temper.most springs are on the upper end of the carbon content.you can take a piece of garage door spring,form quench and temper and have urself a puch thatll mark railsteel all day long,and do it for a while!!!lincoln weld pak 100 hdlincoln ranger 225gxt ac/dcoxy/acetylenepuroxcw202 victor fc100harris model 85harrismodel 16oxweld w24roxweld w17
Reply:Originally Posted by jghdezThanks for the help everyone.I will go with plan B |
