Rod question
发表于 2021-9-1 00:16:25 | 显示全部楼层 |阅读模式
OK some of you pipe welders, I use 6010 all the time for repair work on rusty Amish horse drawn machinery. I just ran across a deal on some 8010, just wondered how it welded compared to 6010. Hate to buy 50 lbs if I wont like it.Trailblazer 302Hobart Stickmate AC/DCLincoln SP 135 TSmith torchSpoolmatic 30A
Reply:Depends on who makes it. Not all 8010 run the same from Hobart to Lincoln and Lincoln to ESAB or whoever. What brand are you planning to buy.
Reply:It would be Lincoln, which is what i've been using only 6010.Trailblazer 302Hobart Stickmate AC/DCLincoln SP 135 TSmith torchSpoolmatic 30A
Reply:It should run similar.
GMT+8, 2025-12-22 21:18 , Processed in 0.095994 second(s), 18 queries .
