More TI.
发表于 2021-9-1 00:16:22 | 显示全部楼层 |阅读模式
I had to build 2 Ti. swing-arms for 05 YFZ'sI made them out of 1.000"  0.070"taste the rainbow Strive For Perfection
Reply:that is so freeking coolChuckASME Pressure Vessel welder
Reply:Originally Posted by chopper5that is so freeking cool
Reply:Titanium? we were shown a peice of that stuff welded at our local welding class and apparently they said the rainbow color meant it had been contaminated, still very nice work.
Reply:Originally Posted by matTitanium? we were shown a peice of that stuff welded at our local welding class and apparently they said the rainbow color meant it had been contaminated, still very nice work.
Reply:Btw, what is a 05 YFZ?
Reply:Bad A$S!! What does something like that sell for?
Reply:Very Nice!...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Originally Posted by WelderBoyYes and no.  The color is only a very minimal surface oxidizing from either traveling too fast and or not having the proper shielding gas coverage post welding.  That happens after the puddle has solidified and the gas is pulled away too quick and the hot solidified steel reacts with the atmosphere.  On a space shuttle or aircraft the risk isn't worth it.  On pretty much anything else, that weld will have the same structural integrity as one that had proper shielding gas coverage.
Reply:I got to play with some titanium the other day.  It's pretty nice to weld.  They were shaft extensions for a backpack drill.  The customer wanted a brushed finish so I stuck it in our finish sander and what a show!  The sparks were so white that you were blinded and it kicked the dimond belt off and destroyed it.  We decided that it didn't need a nice finish afterall.I had to run very short welds because I didn't have the gas coverage that ti requires. If I do more of them, I'll have to pick up one of those 2" cones for the torch.Common sense in an uncommon degree is what the world calls wisdom.
Reply:Originally Posted by WelderBoyBtw, what is a 05 YFZ?
Reply:Originally Posted by tanky321Bad A$S!! What does something like that sell for?
Reply:i would like to make a K frame and lower A arms out of that stuff for my 06 mustang GT ChuckASME Pressure Vessel welder
Reply:Originally Posted by BrooksThere was 2 off them and they sold for $3800.00....
Reply:Originally Posted by chopper5i would like to make a K frame and lower A arms out of that stuff for my 06 mustang GT
Reply:Brooks, I'd really like to know more about your project and Ti expirience.   I am reseaching  snowmobile A-arms and some rear skid parts to do.  Thing is trying to determine the wall thickness to use in Ti or if I have to 4130. The Stock MS is .120-1" to .0930 on different parts.  I was trying to figure out how thin I could go. And still keep the integrety I need for straightline drag racing. Ice Asphalt and grass drags.    One more question......3800.00 because the material is soo expensive or the time and skill for your services.    Just seems  really expensive, but i have not bought any Ti stock yet, just aftermarket parts like the springs we use on the suspension and clutches.  Thanks   Dave500 AMP AIRCO TIG LINCOLN PT185 100% DC @ 128 AMP-WTFSPEED GLASS 9002X MILLER THUNDERBOLT 225HOBBIEST TURNED WELDING JUNKIE8 2ND FIRECAT - SNOWMOBILE RACE CHASSIS FABRICATORPRIDE IS WHAT MAKES YOUR WORK SO GOOD
Reply:Originally Posted by PLUMMERBrooks, I'd really like to know more about your project and Ti expirience.   I am reseaching  snowmobile A-arms and some rear skid parts to do.  Thing is trying to determine the wall thickness to use in Ti or if I have to 4130. The Stock MS is .120-1" to .0930 on different parts.  I was trying to figure out how thin I could go. And still keep the integrety I need for straightline drag racing. Ice Asphalt and grass drags.    One more question......3800.00 because the material is soo expensive or the time and skill for your services.    Just seems  really expensive, but i have not bought any Ti stock yet, just aftermarket parts like the springs we use on the suspension and clutches.  Thanks   Dave
Reply:here is some of Ti I have donethis is for a Mx quad the swing arm had to be built over kill in all that plating there is X braces in thereA-ArmsStrive For Perfection
Reply:Maybe a silly question.  But what are you notching it with?  An abrasive notcher?Lots of toys.
Reply:http://www.arcticcat.com/snow/sled.asp?id=840Try this link until I get more pics. If  you goto the M1000 sled  mountain, or the F1000 sleds you can see the front ski A-arms and then the rear suspension skid parts. Anything tubular.  Obviously weight is our goal to save. So i am not sure on the weight savings between 4130 and Ti. I do know that -for i-ce and- grass -drags -our Ti studs and ice pics are exactly half the weight of normal carbide or hardeneed steel studs.  Now if I can use  .070 4130 to replace  the .120 MS then I can't imagine Ti in .070 would be much lighter, yes?- no?   In drag racing the front suspension never touches the ground until the finishline.  And the rear skid  sees no more than 2" of travel and usually its about 5/8" 90% of the time at launch only.http://www.fastpixs.com/cgi-bin/stor...d_Sleds&img=12Also try this link page 2 and 3 the only green arctic cat sled.  those are 4130 front arms but they dont match the stock shape and configuration, so not leagal in all sanctioning bodies or classes.  That particular sled is a 2003 F7 firecat.  i will try to get my own close up pics or the parts in the shop.I noticed you use plenty of filler but the books and charts I been reading say to just fuse with anything less than 1/16th thick.  Very nice welds by the way.  Why no Ti ????   Thanks again   Dave500 AMP AIRCO TIG LINCOLN PT185 100% DC @ 128 AMP-WTFSPEED GLASS 9002X MILLER THUNDERBOLT 225HOBBIEST TURNED WELDING JUNKIE8 2ND FIRECAT - SNOWMOBILE RACE CHASSIS FABRICATORPRIDE IS WHAT MAKES YOUR WORK SO GOOD
Reply:Originally Posted by brandon75173Maybe a silly question.  But what are you notching it with?  An abrasive notcher?
Reply:Originally Posted by PLUMMERhttp://www.arcticcat.com/snow/sled.asp?id=840Try this link until I get more pics. If  you goto the M1000 sled  mountain, or the F1000 sleds you can see the front ski A-arms and then the rear suspension skid parts. Anything tubular.  Obviously weight is our goal to save. So i am not sure on the weight savings between 4130 and Ti. I do know that -for i-ce and- grass -drags -our Ti studs and ice pics are exactly half the weight of normal carbide or hardeneed steel studs.  Now if I can use  .070 4130 to replace  the .120 MS then I can't imagine Ti in .070 would be much lighter, yes?- no?   In drag racing the front suspension never touches the ground until the finishline.  And the rear skid  sees no more than 2" of travel and usually its about 5/8" 90% of the time at launch only.http://www.fastpixs.com/cgi-bin/stor...d_Sleds&img=12Also try this link page 2 and 3 the only green arctic cat sled.  those are 4130 front arms but they dont match the stock shape and configuration, so not leagal in all sanctioning bodies or classes.  That particular sled is a 2003 F7 firecat.  i will try to get my own close up pics or the parts in the shop.I noticed you use plenty of filler but the books and charts I been reading say to just fuse with anything less than 1/16th thick.  Very nice welds by the way.  Why no Ti ????   Thanks again   Dave
Reply:Snowmobile prostock weight is 550 lbs with driver and sled alone weights anywhere between 360-420 depending on engine500 AMP AIRCO TIG LINCOLN PT185 100% DC @ 128 AMP-WTFSPEED GLASS 9002X MILLER THUNDERBOLT 225HOBBIEST TURNED WELDING JUNKIE8 2ND FIRECAT - SNOWMOBILE RACE CHASSIS FABRICATORPRIDE IS WHAT MAKES YOUR WORK SO GOOD
Reply:these are pretty similar to our drag quadsYou could get away with the lower being 1.000 by .065 and (the upper .875 by .049) thats 4130Ti. lower 1.000 by .070 (uppers 1.000 by.070)for the rear I need to see better picsStrive For PerfectionHow much do one of those YFZ swingers weigh compared to stock?  They look longer too, +6?
Reply:Originally Posted by AcemanHow much do one of those YFZ swingers weigh compared to stock?  They look longer too, +6?
Reply:Wow sorry for bringing back a old thread but Brooks your work is amazing! Being in the atv world myself i gotta say that this TI mx swingarm for the Yfz is TIGHT.
GMT+8, 2025-12-22 20:57 , Processed in 0.099653 second(s), 18 queries .
