disqualification range for welder
发表于 2021-9-1 00:16:15 | 显示全部楼层 |阅读模式
Hi Dear welding peoplei need to ask you a queastion. As you know  for a welder   if he  fail from  Radiographic Examination in  somra ranges ( meybe 95% maybe 90%)   his qualification  be avoked . So is there anyone knows  this range tablo  and which standard contaions that table?Thank you
Reply:It depends on the requirements of the code you're testing to.6 Miller Big Blue 600 Air Paks2 Miller 400D6 Lincoln LN-25's4 Miller Xtreme 12VS2 Miller Dimension 812 4 Climax BW-3000Z bore welders Hypertherm 65 and 85Bug-O Track BugPair of Welpers
Reply:Originally Posted by ExpatWelderIt depends on the requirements of the code you're testing to.
Reply:Your english is a little skewed, so let me make sure I am understanding something right.Your welder is busting out 90-95% of the time?  Regardless of the standard, common sense says he should be removed from the job.Have we all gone mad?
Reply:ASME Codes do not mandate that X Welder has his qualifications pulled after Y number of failed RT shots.  That is a decision that is entirely up to the management, inspectors, and quality departments.
Reply:Thank you all  for your attention
GMT+8, 2025-12-22 22:37 , Processed in 0.092168 second(s), 18 queries .
