oxy/acetylene ratio
发表于 2021-9-1 00:16:15 | 显示全部楼层 |阅读模式
Can somebody tell me how many oxygen cylinders I use to acetylene cylinders?  Is it 2 oxygen to every acetylene?
Reply:Depends on the size of each cylinder, and what you're doing... Welding with 5 psi of both is way different than cutting with 5 psi of acetylene and 30 of oxygen....[Account Abandoned 8/8/16 Please Do Not Attempt Contact Or Expect A Reply]. See you on YouTube! -ChuckE2009
Reply:Have fun:http://tinyurl.com/3b5rma4
Reply:like was said above...depends on what you are doing.  The best deal I ever had going was when I was doing a lot of cutting and using propane w/oxygen.  then got (2) 250cf bottles of oxygen to one five gallon propane. But that was pure cutting and heating.Your mileage may vary.
Reply:2-1 for general cut is about right. It will vary with regulator settings.Miller Pro 30068 SA 20064 SAF 300305 G Lincoln gasserMiller 210
Reply:it depends on what your doing. however, a normal oxy/fuel setup is one cyclinder oxy 1 cyclinder fuelWELD TO LIVE LIVE TO RIDEA bad welder blames his equipment, a good weldor can lay a perfect bead on any thing
Reply:For a general rule of thumb, i go through at least 2 oxys for every 1 acetyleneSteve1946 Shorthood  -  1958 Blackface  -  1962 Redface  -  1967 Redface  -  1968 Redface -  1970 Blackface  -  2005 300D -  2008 Vantage 300  -and a ton of other welding stuff
Reply:i have a 140cubft gas,250cubft oxy.get 2 to one when cutting. welding a lot will change that ratio considerably especially if u weld stuff bigger than 1/4 inch.even so u should still be able to make em last a while unless there real small tanks. dont waste ur money on those less u want that oxy bottle filled all the timelincoln weld pak 100 hdlincoln ranger 225gxt ac/dcoxy/acetylenepuroxcw202 victor fc100harris model 85harrismodel 16oxweld w24roxweld w17
Reply:the ideal burn ratio is 5 volumes of O2 for every 2 volumes of acetylene2 C2H2 plus 5 02 yields 4C02 plus 2 H20you get a bit of O2 from the air, so in reality the O2 requirement is somewhat less
Reply:I have one of each and try to size them so that I can make 1 visit to the LWS for a refill for both (since local is really a 100 mile round trip).Hobart LX235Victor 250 Oxy-Acetylene Rig (welding and cutting)Bobcat 773F-350, 1999, 4x4, 16' 10K# trailerOutdoor Wood Burner - 10 cords/year
GMT+8, 2025-12-22 21:17 , Processed in 0.093110 second(s), 18 queries .
