stick or MIG????
发表于 2021-9-1 00:16:15 | 显示全部楼层 |阅读模式
hello all! I am a 23 year old aluminum welder.. I've been welding aluminum for 5 years so far. My buddy asked me to do some welding for him on the frame of a 1927 T-bucket he is restoring and I was just trying to get some opionins on which would be a better option... a MIG welder or a stick welder. if anyone could help me out that would be awesome! Thanks! -JB
Reply:mig or tig however, what will you be welding on if its sheet metal or frame mig, if its the engine block or trans bell i would use a nickel rod or a hight nickel sst rod because it would be made of cast iron. and steele is a hole difernent animal. so i would get some scrap steel to practice onLast edited by USARMY44B; 04-19-2011 at 07:25 AM.WELD TO LIVE LIVE TO RIDEA bad welder blames his equipment, a good weldor can lay a perfect bead on any thing
Reply:I would say it boils down to the process you are most comfortable with. Both processes are fine in capable hands, also when you say Aluminum welder are you saying you don't have a lot of experience welding steel? If thats the case you may want to turn down the project. Your weld your liability.
Reply:some of the classic guys like OA welding as that is how a lot of that was done originally.  same with body work,  they want the lead fill instead of bondo...Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:Details of what you are welding would help us give an opinion. Frame, body panels, and etc.Miller Pro 30068 SA 20064 SAF 300305 G Lincoln gasserMiller 210
Reply:In the auto body repair industry it is predominately Short Arc MIG from body panels to frames.  A fair amount of Resistance Spot Welding on panel replacements, and a small amount of TIG for fine work and exotic metals.Jay DavisAWS-CWIC-60 Specialty Welding ContractorLoving husband, and father of two boys (
Reply:You say you have been welding aluminum for five years.What process were you using to weld the aluminum?AWS certified welding inspectorAWS certified welder
GMT+8, 2025-12-22 21:20 , Processed in 0.097201 second(s), 18 queries .
