What do I need for this job??
发表于 2021-9-1 00:16:13 | 显示全部楼层 |阅读模式
I am new and never welded before and I want to make a bbq pit/rotissary pit for hogs.. can anyone tell me a beginner set of equipment i need to do this? im deployed and dont have time to read through all through all the helpful topics im sure are posted. ps. just the basic kit to get started.. I can learn how to do it on my own thanksadam
Reply:#1 piece of equipment you will need is a high limit credit card.#2 Time to study what others have done and how they did itI offer three choices: Good, Fast, & Cheap. You may pick two.Hobart AC/DC StikMate LXHarbor Freight AD HoodHarbor Freight Industrial Chop SawDeVilbis 20 Gallon, 5 HP Compressor
Reply:I suspect many folks would vote for a MIG.I would vote for a simpler setup based on stick- DC capable stick welder (220v).- autodark helmet (don't bother with passive shade)- chipping hammer- 7018 rod, both 1/16 diameter (for thin material) and 1/8 diameter- welding gloves- welding jacket- face shield & safety goggles- 4 1/2" angle grinder- cutting and grinding disks for grinder- soapstone for marking the steel- sander (orbital or disc) with sand paper- high temp paint- a few good clamps, (C style or vice grip style)- Northern Tool DVD on ARC welding (get both #1 and #2 if you can)- Finch or some other book on weldingYou will want enough scrap to practice on.  When you are new to welding it is a good idea to test your ability to weld a specific joint with the same material you are using BEFORE you strike an arc on the work piece.  I learned the hard way - when you are self taught you need to take the time to practice.That should get you set up well enough to learn and build the BBQHobart LX235Victor 250 Oxy-Acetylene Rig (welding and cutting)Bobcat 773F-350, 1999, 4x4, 16' 10K# trailerOutdoor Wood Burner - 10 cords/year
Reply:your attention is invited to                http://www.weldathome.co.za/index.htmI offer three choices: Good, Fast, & Cheap. You may pick two.Hobart AC/DC StikMate LXHarbor Freight AD HoodHarbor Freight Industrial Chop SawDeVilbis 20 Gallon, 5 HP Compressor
Reply:You need a 13 piece barbeque set. Also a LOT of sauce.AWS certified welding inspectorAWS certified welder
Reply:Lincoln ac/dc cracker boxes are plentiful and cheap. You can buy assemblies to auto rotate. What you need, will depend on whether you are building a pit out of plate or pipe.Miller Pro 30068 SA 20064 SAF 300305 G Lincoln gasserMiller 210
Reply:The best way to learn is DIY!Just starting out, a 110 mig, an oxy/fuel cutting setup and a grinder with1/4" grinding disks and zipcuts as well as a power brush; a welding helmet , possibly a chipping hammer.  Tape measure, square, level, clamps, soapstone/silverstreak, determination, gumption and persistance!  Last but not least (arguably the most important item!), a digital camera so you can post pictures here!  A basic understanding of the process you plan to use also helps!Last edited by mb_welder; 04-20-2011 at 08:06 PM.
Reply:Once you get the equipment you need and start building stuff maybe you could get on a TV show like I did when I built the Turkey Bike Rotissiere for the Food Channel a few years ago...LOL.Here is the link.http://www.tjsperformance.com/hamonstreet.htmwww.tjsperformance.comDynasty 300 DXHTP 240HTP Microcut 380Hyperthem 85JD2 Hyd Bender and HF Hyd Ring Roller all in one =(Frankenbender)Bpt. Mill/DRO4' x 8' CNC Plasma TableInstagram: tjsperformanceYT: TJS Welding and Fabrication
Reply:Originally Posted by gwileyI suspect many folks would vote for a MIG.I would vote for a simpler setup based on stick- DC capable stick welder (220v).- autodark helmet (don't bother with passive shade)That should get you set up well enough to learn and build the BBQ
Reply:I too recommend an autodark helmet.  It willmake you a better welder annd speed your produuction.I have owned both an automatic and a passive helmet, I gave the passive helmet away after I learned how nice the automatic helmet is.I offer three choices: Good, Fast, & Cheap. You may pick two.Hobart AC/DC StikMate LXHarbor Freight AD HoodHarbor Freight Industrial Chop SawDeVilbis 20 Gallon, 5 HP Compressor
Reply:I would either go with a small mig with flux core or else a small stick welder but go with a 6011 or 7014 if you are just starting out.  A small grinder to cut and polish and go from there depending on budget.  The nice thing about metal is you can always cut it appart and redo something if you dont like it.  Most important is cold beverages, and time to think and plot it out.  I see you are deployed, god bless you and thanks for your service.Millermatic 252millermatic 175miller 300 Thunderboltlincoln ranger 250smith torcheslots of bfh'sIf it dont fit get a bigger hammer
GMT+8, 2025-12-22 21:16 , Processed in 0.194593 second(s), 18 queries .
