need help with scroll bender
发表于 2021-9-1 00:16:10 | 显示全部楼层 |阅读模式
Hi guys, I have spent the last three days trying to build a scroll bender for ornamental iron work, I have cut, bent, welded, swore and cut again and cannot make it work. Does anyone have a drawing for the inner and outer dies? If someone has a good bender would you consider taking a couple of pictures looking down on the two pieces with maybe a ruler or something for size reference, I can then scale it from that, any help you can offer might save the last two hairs on my head.ThanksTerry
Reply:I have a scroll bender that works with a Compact Bender frame. I can get you some pics tomorrow, if you're looking for that type of bender.--------------john
Reply:i bought one from shop outfitters works great Attached Images
Reply:Thanks for the replies, I am looking to build one like the one shown on the post from ed mac. I know it looks simple enough but all the angles and curves seems to escape my fuzzy old brain.Terry
Reply:Perhaps this will helphttp://weldingweb.com/vbb/showthread.php...=scroll+golden
Reply:Thanks tapwelder, I'll give it another try.
Reply:if you're having trouble plotting the spiral you might want to look this over:  http://www.mathematische-basteleien.de/spiral.htm
Reply:Cool stuff.  Thanks WillieB.  I'll have to keep that site as reference.
GMT+8, 2025-12-22 21:23 , Processed in 0.067354 second(s), 18 queries .
