Lincoln 3200HD? need portable 120v welder
发表于 2021-9-1 00:16:09 | 显示全部楼层 |阅读模式
I bought this unit from Home Depot, it can do up to 5/16" steel. It can be a portable unit while I go offroading, & run it off my 120v generator. I need some feedback on this unit, is it a good performer? What are some "+"'s & "-"'s? I can always return it, if there is a better unit out there.
Reply:Originally Posted by byen00I bought this unit from Home Depot, it can do up to 5/16" steel. It can be a portable unit while I go offroading, & run it off my 120v generator. I need some feedback on this unit, is it a good performer? What are some "+"'s & "-"'s? I can always return it, if there is a better unit out there.
Reply:Originally Posted by byen00 it can do up to 5/16" steel.  run it off my 120v generator.  if there is a better unit out there.
Reply:3200HD is rated 20A input, that's 20 x 120v = 2400W (continuous?, or does the 20% duty-cycle play into the equation). I have a portable Honda EU2000i (2000W max.(16.7A) 1600W rated (13.3A)), would it work?Right, I would use flux-core for 4x4 mobile situations.
GMT+8, 2025-12-22 22:54 , Processed in 0.069563 second(s), 18 queries .
