Rod Holder Brackets
发表于 2021-9-1 00:16:00 | 显示全部楼层 |阅读模式
In an attempt to organize my Chaos I ordered some Rod Holders from IOC...Then I needed a Bracket to hold the Holders.Used my little HF bending BrakeThe test piece- I didn't have the brake set up correctly and the bend was funky- and that is why we have a Test pieceEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Couple more Pics- didn't wanna load up the post with too many pics fer our Dial-up buddiesEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:What did you you use to cut the large dia. holes?The brake seems to do a good job.  I've been looking at one from Northern Tool for my hyd. press."Any day above ground is a good day"http://www.farmersamm.com/
Reply:Originally Posted by farmersammWhat did you you use to cut the large dia. holes?The brake seems to do a good job.  I've been looking at one from Northern Tool for my hyd. press.
Reply:Slick idea Ed.  What's the material?Mind if I copy that for my newly aquired SW180SD?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Originally Posted by duaneb55Slick idea Ed.  What's the material?Mind if I copy that for my newly aquired SW180SD?
Reply:Originally Posted by Broccoli12" Hole Saw in the Ryobi- you cab see it on the Table
Reply:Originally Posted by Broccoli118g Steel.I purchased the Rod Holders from IOChttp://www.weldingsuppliesfromioc.co...for-tig/Detail
Reply:Originally Posted by farmersammSo Duane..... When we gonna see the new toy in its new home?????
Reply:Originally Posted by farmersammThe battery operated power tools have come a long way since I first looked at them.  It takes quite a bit of torque to cut a hole that size.  Were you able to do it all on one charge?Beats the daylights outta trippin' over cords.  I am constantly at war with cords, hoses, cables, and the dog.  Somethin' always manages to get under my feet, or I pick up a drill/grinder etc. and find it's not plugged in.
Reply:Originally Posted by Broccoli1They just came out with the New batteries and they work on all the old tools so I have just been upgrading batteries slowly- the new ones Kick butt!!.
Reply:I like the idea.  I have the same rod holders and they are standing up in a tube frame that I build some years ago.  The problem is that they shift around and it is difficult to twist the cap when they are leaning on themselfs, especially when you are in a hurry.  I think I have about 15 of them total.  Thanks again for the great idea.-MikeCommon sense in an uncommon degree is what the world calls wisdom.
Reply:Oh! welding rod holders, I fish too much. Nice work BroccoliYup
Reply:Originally Posted by duaneb55Are those the ones that have a charge indicator and run strong right up until the need a charge and 'shut off'?
GMT+8, 2025-12-22 21:41 , Processed in 0.115608 second(s), 19 queries .
