It's Getting Bigger
发表于 2021-9-1 00:16:00 | 显示全部楼层 |阅读模式
Fitup work on frame.Don't ask, it ain't done yet. Attached Images"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Jeez, whatever it is it sure looks pretty heavy duty!
Reply:Judy says the calves are getting bigger - it must be a new feeder.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Originally Posted by duaneb55Judy says the calves are getting bigger - it must be a new feeder.
Reply:Looks like the beginnings of a Pnue, Pneu, Num- ah sheet-- an  Air powered Can Crusher for about 70 cans at a timeEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Does the dog wear a welding mask or goggles?Does it hook to the front of the tractor like a plow frame or the 3 point hitch?Too narrow to pull 2 rakes side by side, not a hay spear.....David Real world weldin.  When I grow up I want to be a tig weldor.
Reply:Mmmm,, I reckon it's for the 3 point linkage and it might be an extended carrier for a hinge mounted magnetic strip to pickup up extraneous metal from the pasture.I think the dog makes sure no-one run away with the vice."One of the things we have to be thankful for is that we don't get as much government as we pay for." (Charles Kettering)Mitch 180 (NZ)Lincoln SAM-400-220 + ?-400 Fordson Major + 2 x Tractapac Humber 80 + Procut 40 PlasmaMiller Spectrum 375
Reply:It's obviously a can/cup holder for a 3pt...The best things in life all come on a stick!
Reply:Heavy-duty headliner support?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:dogs doin fire watch!!!*SAFTEY FIRST*
Reply:You guys are all wrong I think. It looks like the backbone/ skeleton to a mechanical bull. Are ya opening a honky tonk, FarmerSam??!!And then, after so much work...... you have it in your hand, and you look over to your side...... and the runner has run off. Leaving you holding the prize, wondering when the runner will return.
Reply:I think it's a pumpkin launcher. Probably going to debut at the big harvest party, for the "knock the transformer (lineman?) off the pole " contest.
Reply:I'll admit I don't have a clue and this is keeping me from my breakfast. I'll check in later and see what it is.
Reply:Originally Posted by Broccoli1Looks like the beginnings of a Pnue, Pneu, Num- ah sheet--
GMT+8, 2025-12-22 21:41 , Processed in 0.069665 second(s), 19 queries .
