Misc. shop jobs
发表于 2021-9-1 00:15:59 | 显示全部楼层 |阅读模式
I had to make a vented cover for a customer and didn't really know how I was going to do it.  So I stared off cnc plasmaing the part with slats down the middle.  Then I put some square tube along either side to support the ends of the slats.  Then I used a chisel to punch each slat about 1/2" in from the ends.  I worked one side, flipped it over and did the other side.  I flipped it a total of 4 times.  It turned out pretty nice looking.The other picture is a diaphragm pump for a local cannery.  They wanted a frame for it to roll around on.  I thought it was interesting because I had never seen a pump quite like it.  To give it scale, the hose is 2".  I think he said they run about 10K new. Attached ImagesCommon sense in an uncommon degree is what the world calls wisdom.
Reply:I like the chisel idea for the slats.  May have to use that one myself!
Reply:Now I know why we build all those welding carts!You are an artist with sheet metal.David Real world weldin.  When I grow up I want to be a tig weldor.
Reply:we use those sandpiper pumps at my work I like that cart we have one or two permanent installed and a couple that we can set up for flooding I am probably steal your cart idea the temps usually get set  out of the back of the truck and hopefully dont end up in the sump there pumping out due to the pump cycling... Awesome workAndyA.K.A BDB (Big Daddy Boynton)
GMT+8, 2025-12-22 21:39 , Processed in 0.067391 second(s), 18 queries .
