what size breaker should i install for a lincoln 175. i bought it used and no paperwork. i was going to swing off of the 30 amp breaker where my dryer was. any ideas would ge be greatly appreciated.
Reply:i'd think that would be ok..30 amps seems like enough..however i'm no electrican...but i did stay at a holiday inn last night.... ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Originally Posted by backuprollerwhat size breaker should i install for a lincoln 175. i bought it used and no paperwork. i was going to swing off of the 30 amp breaker where my dryer was. any ideas would ge be greatly appreciated.
Reply:thanks for the replies. i guess it's a good thing i got rid if the dryer and make the wife hang clothes out to dry {lol}, just kidding. added a wash room off the back cause she didn't like standing in the garage to do laundry. more room for me to turn an burn.
Reply:While the manual recommends a 40A breaker, Lincoln's manuals are notoriously confusing as to why. These machines run very well from 30A breakers, but it is incorrect to state that they draw only 21A. That is at its "rated output" of only 130A. It will draw significantly more at their maximum output of 175, just at a lower duty cycle. This is why you must make sure it is a 30A time-delay breaker, which most are.
Reply:Fuse or Breaker Size 40 Super Lag, for either "plus" or tapped modelspdf's available online....for "plus" models... ( http://content.lincolnelectric.com/p...r/im/IM790.pdf )http://content.lincolnelectric.com/p...ature/e735.pdf for tapped models... ( http://content.lincolnelectric.com/p...r/im/im726.pdf )http://content.lincolnelectric.com/p...ature/e734.pdf
Reply:As mentioned, the Lincoln manuals are misleading. Naturally, it will operate just fine from a 40A breaker and #8 wire. It's your money.
Reply:Probably around 27± amps at maximum of 175 to 180 amps, with a 10% to 15% duty cycle. So you've got a minute or a minute and a half at just under thirty amps before the machine either craps out or starts to act erratically on a 30 amp breaker. Of course a lot of that has to do with the type of wire and whether you've got it really buried in there good on nice hot run or not. Most of the time it would be a rare occassion or an accident if you reached the 175 amp output with out some prior planning to do so. I've stuck my tip and/or diffusor right to the work piece and managed to let off the trigger before tripping a 30 amp breaker. |
